Oil filter housing leak
2015 ml350 bluetec / 4JGDA2EB0FA570972
hope the picture helps, it looks legit leaking. I might do it when I change the engine oil with fuel filter, air filter etc in august. Oil level seems fine, so the leak mustn't be much. I didnt think the black cooler thing to be blocking even when changing belts...as always thank you for any help , comments and guidance. I need to figure the part #..
Todd
Not one hour and not 8 hours. Somewhere in 4 hours +/- an hour or two.
Adhering to torque specs is important, and also replacing screws when specified is important. MB uses aluminum and magnesium on the front/upper parts of engines, if not using plastic. Al and Mg are weak metals and Al screws are often used with VERY low torque specs, and these Al screws are single use (must be replaced). Not sure if this applies to the oil filter housing on the OM642, but is offered here as a general precaution.
These engines are about as far away as you can get from a small block Chevy.
Part # 642 180 141 064
The replacement is not difficult as I recall it.
