1st post
Old May 24, 2025 | 05:30 PM
Papabear56's Avatar
2013 ML 550
Smile 1st post
My name is Lee. I just bought a 2013 ML 550 AMG edition. I love my car. Im working on it now. But once I get it cleaned up I will post some pictures. The #5 coil is bad and created a permanent code. So while I wait for my coil to arrive im trying to get everything ready. I gotta find the battery so I can disconnect it. Do I need to disconnect the secondary battery as well? Anyway. Its great to be here.<!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->
Old May 24, 2025 | 08:20 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W166 forum...
Old May 25, 2025 | 04:30 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
COIL OR CYLINDER
Yes disconnect BOTH!
As soon as you disconnect primary, secondary is forced to drain.
Knock on wood about Cyl#5 misfire to be resolved with one new coil.
In case it keeps misfiring save your time without dealing with injectors... BORESCOPE cylinder walls and piston crown - Cyl.#5 75% likely to have low compression. The question is how much losses?
