Fuse box next to battery
Scott
Scott
Perhaps the solution is nowhere near that... MB fuseboxe seldom go bad.
Factory painted GND posts do need attention.
Single main GND STRAP is mounted all the way undercariage in road splash area.
"No Crank" can be a failure of drive authorization. Scanner will help you progress a lot faster than fuses by getting access to live chassis status.
Battery charger/maintainer :
Battery tester: This one paid itself already: diagnosed sister's battery, and the neighbors' Camry's battery and alternator. It saved my neighbor from having to install a new alternator, as diagnosed by a shop.
Creader Elite: AliExpress Creader Elite v2
Battery charger/maintainer : CTEK
Battery tester: TopDon Battery tester
Then why not start right there... so you can use an DVM /Ohmeter while all power's out.
Why?
Because fuse links are bolted on inside the Prefuse-box near battery.
Why?
I have attached a photo of the fuses I am trying to access. They face up, so you can't pull them. There doesn't seem to be a logical way to move the plastic bracket so you can access the fuses to test.
I picked up a more modern scanner and there are multiple modules offline, so I believe one of these main fuses is blown. I have found several forum post with the same issue on the W166, but none of them have an actual way to remove these fuses.
Thanks for the assistance!
Did you have engine running and still a few ghost modules... that's an issue.
What modules names /fault: live or stored?
Water leak issues can.bring down CAN-Bus to silence multiple modules.
Scott
