OM642 Vin decoding?
Old Mar 30, 2026 | 07:11 PM
12Blue's Avatar
2012 ML350 Bluetec
OM642 Vin decoding?
I purchased a wrecked 2012 ML350 Bluetec with plans to swap everything over to my high milage ML350 that is burning oil pretty bad. The wrecked car runs pretty well however when I started pulling the engine I noticed some bolts were missing or replaced with the wrong hardware. Hmmm someone's been here before! I got the engine/trans dropped last night which wasn't to bad using a hydraulic table and my MaxJax lift and low and beyond, back of the engine had an LKQ stamp on it... Uugh...
I'm trying to decode the vin on the engine to find out specifically what car it originally came out of. Not to worried but would be good to know. Anyone have access to EPC that can look up the body vin number from the engine?
Engine Vin shows: 642 826 41 221 697
Thanks in advance!
Brian
Old Apr 2, 2026 | 09:30 AM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
Thanks in advance!
Brian
Need the vehicle VIN to look it up.
Old Apr 2, 2026 | 10:35 AM
12Blue's Avatar
2012 ML350 Bluetec
Hi Joe,
I haven't used EPC in a while but there is no reverse lookup where you can plug in the EIN to get the original vehicle VIN?
The EIN is: 642 826 41 221 697
Thanks for your help.
Brian
Old Apr 2, 2026 | 01:37 PM
jmattioni's Avatar
Hi Joe,
Brian
Sorry, I see no way to do that. PM me the VIN if you don't want it on the forum.
Old Apr 2, 2026 | 02:45 PM
12Blue's Avatar
2012 ML350 Bluetec
Hi Joe,
I'm slowly coming to the conclusion that what I'm asking of EPC isn't an option.
I have an engine purchased from LKQ that was installed in a known W166. I have the vin of my existing car and can lookup the original engine via last vin.
VIN 4JGDA2EB6CA026133 <--- Wrecked car I purchased
Model Year 2012 Model ML 350 BLUETEC 4MATIC
Engine (EIN) 642826 41 208785 <--- Original EIN from the vin 026133 above
What I'm looking for is the vin number of the engine purchased from LKQ so I can pull a CarFax and look up its history. The EIN on the LKQ engine is: 642826 41 221697
I also tried contacting LKQ and was told they don't store car vin's or engine serial numbers.
I wish Mercedes would simply print the original car vin on the engine but for this case its not possible
Thanks again,
Brian
Old Apr 2, 2026 | 04:02 PM
jmattioni's Avatar
Hi Joe,
Thanks again,
Brian
I may be able to help. I have offline EPC and know how to get into its database tables. Since the 2012 year is within the offline EPC data I may be able to do a search on engine number. I'll give it a try.
Old Apr 2, 2026 | 04:49 PM
jmattioni's Avatar
@12Blue Think I found it! That engine came out of 4JGDA2EB9CA032654. Datacard attached.
Old Apr 3, 2026 | 10:08 AM
12Blue's Avatar
2012 ML350 Bluetec
Joe, sincerely appreciate you pulling the card via EPC! My old Dell laptop gave me a Java error when I open EPC so... I have other challenges :P I did a quick google search and found its matching transmission LKQ sold back in 2023 out of the state of Washington so this matches up!
Milage on that engine back in 23 was 67k. Sounds like I really made out good here! The wife and I love our diesel. I knew the engine would eventually have troubles based on its high milage and extended oil intervals prior to our purchase. I did what I could for the last 50k miles using liquamoly every 5k miles but the oil control rings were clogged, I had injector issues which washed the fuel and a worn oil pump resulting in what sounds like a rod knock. Thanks a ton! I'll get back to cleaning her, replacing the oil pump, cleaning up carbon and prepping her for a re-install. Cheers!
Old Apr 3, 2026 | 04:55 PM
12Blue's Avatar
2012 ML350 Bluetec
Hey Joe. Few people have pinged me 1:1 asking where you found this search in EPC? Mind sharing where you searched the EIN to pull the datacard? Thanks again -Brian
Old Apr 3, 2026 | 06:57 PM
jmattioni's Avatar
As you probably know, the EPC app only supports searching on VIN or FIN. But behind the app is a relational database service that manages access to all the data. It takes technical knowledge, and a couple of bits of info, but it's possible to talk directly to that server and do much more extensive queries.
Unfortunately, that trick is possible only with the offline EPC where the service is running in the background on your own PC. Offline EPC has data up through early 2019.
Beyond that you have to subscribe to MBs online service, where you can no longer get to the database.
