SL600 intercooler system ?
Question is how to bleed the system, I searched the forums and all I found was info on the Supercharged cars.
What should our IATs be during normal cruising? I'll hook up my data logger up to my hooptie tomorrow and drive it to work, and see what I get. Unless it's raining, of course.
Either my pump is not working or there is air in the system. I'll figure it out tomorrow evening when we can get the car on a lift.
Remove the engine cover and start the car. There is a little tire valve stem looking thing in the back near the intercoolers. Push it in and if it pees liquid, your pump is good. If not, your pump is bad.
Thanks, I also just found a bleed procedure in this same section
Needless to say, my car is getting a new OEM "Charge Air Circulation Pump" installed this week when parts some in, and the cooling system/intercooler system will be flushed/refilled. Curious to see whether performance will change or improve.
Aaron
