M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Understanding Intercooling, Charge-Coolers, Heat Exchangers and Circulation Pumps
Rating: Thread Rating: 5 votes, 5.00 average.
Old 03-13-2016, 06:04 PM
  #251
Mackhack's Avatar
It seems like the Pierburg pump is working in an E55 and runs about 3x as much water as the EWP-80.
I'll order a Pierburg which is in the Black Series and give it a try.
B Feelgood (06-01-2016)
Old 03-14-2016, 06:13 AM
  #252
SL65MONSTA's Avatar
SL65
Nick , I have my half front end of the car, I also bought a Bosch 010 pump accidentally , I want to run a second HE cooler, a few questions.
1. do you suggest I do this, will it improve cooling?
2. if I did should I run the second pump I bought? if so how far apart?
3. Should I wire them to run on always, or leave the system as it is per factory?
4. is the coolant type the same as the cars motor coolant?
sorry for so much questions. But you seem to be the man to talk to regarding the V12 cooling.
Thanks in advance
Old 03-14-2016, 06:40 PM
  #253
Welwynnick's Avatar
2006 S600
Originally Posted by Crissus
Are you sure? This would be very good for us CWA-100 users like myself. I still dont know if my CWA-100 runs at 100% or not. I direct wired it with an BMW connector. One person in this thread here or the other said, he removed pump cover and directly attched the wires to the pump without connectors and therefor bypass that PWM singnal stuff.
The answer is on post 228.
This is all the information that I have:
http://s1.teamlearn.de/QuickPlace/b-...0waterpump.pdf
http://webpages.charter.net/n8nxf/EV...ant%20Pump.pdf
https://mbworld.org/forums/m275-v12-...ml#post6395913
Old 03-14-2016, 06:46 PM
  #254
Welwynnick's Avatar
2006 S600
  1. Yes, two intercoolers will improve cooling, but I would run them in parallel rather than series, to avoid reducing the flow through the IC's.
  2. Yes, running a second pump of the same type is always a good idea, as long as its installed properly, and doesn't cause airlocks.
  3. I wouldn't run a CWA-100 always, as it tends to froth the coolant, but the Bosch is OK. Only problem the commutator bushes wear out, so the motor doesn't last very long. The Pierburgs don't have that problem.
  4. Yes, the IC uses the same coolant as the engine, though I would run a lower proportion of anti-freeze.
Nick
Old 03-17-2016, 12:54 PM
  #255
SL65MONSTA's Avatar
SL65
Nick
How do you suggest I run them in parallel , each inter cooler has its own cooler or just run both coolers of a dividing y pipe splitter ? Also about the pumps should I wire them to run continuously as the car is turned on , or leave as factory set up ? Thanks heaps again
Old 03-27-2016, 04:44 AM
  #256
Welwynnick's Avatar
2006 S600
This is what a parallel intercooler configuration looks like, schematically:
Understanding Intercooling, Charge-Coolers, Heat Exchangers and Circulation Pumps-a1bb34ad-8ac4-4868-9b78-d2de841f7e24_zpse0040d9a.jpg
And this is what it looks like in practice. On my car, at least. Mercedes use metal pipes with right-angle T-junctions, which limit flow.
Understanding Intercooling, Charge-Coolers, Heat Exchangers and Circulation Pumps-pb120564_zps31858284.jpg
You can find the Y-pieces by doing an eBay search for "3/4 Y connector"
Nick
Old 03-27-2016, 10:48 AM
  #257
SL65MONSTA's Avatar
SL65
I have two pumps , plus a spare Ai condenser which I've been told is best to use as a cooler for the IC system including the stock unit, however the inlets on the condenser are tiny , would putting a y pipe connector with a reducer work ? One would think it would restrict the flow
Old 03-27-2016, 02:47 PM
  #258
Welwynnick's Avatar
2006 S600
It was one of the first things I thought of three years ago, but I wouldn't consider using an AC condenser, as the coolant flow would be too low.
Nick
SL65MONSTA (03-27-2016)
Old 03-27-2016, 03:41 PM
  #259
SL65MONSTA's Avatar
SL65
Nick
What about if i air die grind out the pipes from the AC line (tiny piping) to the standard 3/4 piping, would that fix the flow issue ?
Old 03-27-2016, 05:17 PM
  #260
SL65MONSTA's Avatar
SL65
Sorry i forgot to add into the digram the heat exchangers too, but you get the gist of my idea
Old 03-28-2016, 04:05 AM
  #261
Welwynnick's Avatar
2006 S600
What about if I air die grind out the pipes from the AC line (tiny piping) to the standard 3/4 piping, would that fix the flow issue ?
Sorry I forgot to add into the diagram the heat exchangers too, but you get the gist of my idea
Yes that would work well. Just make sure you get all the swarf out of the pipes.
Nick
SL65MONSTA (03-28-2016)
Old 03-30-2016, 01:30 PM
  #262
MrDangerUS's Avatar
LOTUS ESPRIT TURBO
Could anyone chime in with CWA-100 part numbers, please (BMW preferred)
Is BMW E60 - 5 Series = Electric Water pump 11517586925
an intercooler or engine water pump?
Attached Thumbnails Understanding Intercooling, Charge-Coolers, Heat Exchangers and Circulation Pumps-bmw-e60-5-series-electric-waterpump-11517586925.jpg
Old 03-30-2016, 03:22 PM
  #263
Welwynnick's Avatar
2006 S600
The pump in the picture is an engine pump.
Nick
MrDangerUS (03-30-2016)
Old 04-09-2016, 06:25 AM
  #264
Welwynnick's Avatar
2006 S600
CWA 50 . Circulation pump, 50W , 6000 rpm, 24 lpm @ 0.60 bar
CWA 100 Circulation pump, 100W, 7200 rpm, 30 lpm @ 0.85 bar
CWA 200 Coolant pump, 200W, 4500 rpm, 120 lpm @ 0.45 bar
CWA 400 Coolant pump, 400W, 10000 rpm, 150 lpm @ 0.80 bar
The CWA 50 is used as a charge cooler pump on the recent BMW V8TT engine, and the CWA 200 is used as the coolant pump on a wide range of recent BM's. The circulation pumps have relatively low flow and high pressure, while the coolant pumps are obviously high flow. Like all good pumps, they're specified by their flow rate under pressure, so we know what their installed performance is going to be.
The CWA 200 & 400 coolant pumps are off the chart, flowing over 100 lpm, and I didn't even try to plot them. They're huge, but you can see they meet different requirements. Where the 50 & 100 (like the Bosch pumps) fit the Charge Cooler Resistance curve pretty well, the 200 & 400 are closer to the Engine Resistance characteristic.
Nick
I used Pierburg CWA-50, -100 and -200 pumps on my car, largely because I couldn't find any CWA-400. In fact, I didn't think there were any, but I found this on ebay.de last night:
http://www.ebay.de/itm/Tecomotive-ti...IAAOSw14xWLrEw
I used to think they were superseded in the BMW line-up by the VDO pump, but that's not the case. They do exist and they are commercially available. They use different electrical connectors, but I don't think that's a problem.
I'm just trying to figure out how to reliably identify one, and what the part numbers should be. You can't believe everything you read, especially from someone selling car parts. I think the best guide is that this pump was used on the BMW 4 cylinder 2 litre turbo engine, used in the 328i, 428i, 528i and similar models. I'm not 100% sure yet, but I believe the BMW part numbers are:
11517596763
11517604027
I believe this is the Pierburg part number for the CWA-400. I've seen other P/N's used, but I don't think they're right. The -66- dash number appears to be the most common, but there a dozen others.
7.03665.66.0
The CWA50 and 100 look alike. Some have quick-fit ports, and some need hose clips. You can't distinguish them by appearance.
The CWA200 has 4 bolts holding the impeller housing, and two bolts holding the electronics housings. The CWA400 doesn't.
The CWA50 & 100 use the same connector, but otherwise they all use different connectors.
Nick
Old 04-10-2016, 05:15 AM
  #265
Welwynnick's Avatar
2006 S600
To complete the picture, this is the Siemens / VDO / Continental pump that's used on the 3.0 litre turbo gas engine in the recent 135i, 335i, 535i, 640i and similar.
Common BMW part numbers are:
11517563659
11517588885
11517632426
I believe two VDO part numbers are
A2C59514607
A2C53326031
Since this is used on the bigger engine, I presume this is even more powerful than the CWA-400 pump, but there's not much information about it.
http://ows-cdn.tecdoc.net/vdo/home.j...37ef248a4c0a90
It looks like the connector is the same as the CWA400, but hard to be sure.
Hopefully the control signals are the same, otherwise not much interest in the context of this thread.
I've just bought one to play with, so will find out soon.
Nick
Old 04-10-2016, 10:35 AM
  #266
Welwynnick's Avatar
2006 S600
A datasheet at last - hurrah!
http://www.easycarparts.nl/Controls/...9514607_DS.PDF
Operating point 0.80 bar at 9000 litres per hour = 150 l/min
So about the same as the CWA400.
Nick
File Type: pdf
Old 04-23-2016, 07:12 AM
  #267
AMG-Driver's Avatar
SL65 R230
Excellent Info.Thank you very much,especially to Nick.
Now my Pump seems to be dead, checked Fuse and it was o.k.
Want to get the CWA100 now. Is the latest info still without a control module Ground1 ,Battery4, 1.5 kOhm resistor3 and it works with (nearly) 100% power? What are the connecting parts and mounting brackets? Anywhere good prices for the pump, and is the cwa100 worth the price in daily driving over the cwa50 which is also used in many VW/Audi applications. Many thanks!
Old 04-23-2016, 09:01 AM
  #268
Mackhack's Avatar
Send me a PM.
Old 04-30-2016, 12:15 PM
  #269
MB-CLS500's Avatar
CL600 W216
Does anybody know how much Volts and Amps our Cars use for powering OEM intercooler pump? 12v 14v or 24v?
Old 04-30-2016, 12:28 PM
  #270
Mackhack's Avatar
We have a 12V battery on board.
Old 04-30-2016, 12:40 PM
  #271
MB-CLS500's Avatar
CL600 W216
I bought EMP WP29 pump it operates 12v and 24v I want to install it on my 07 cl600 with 24v is there anyway to attach + - wiring on to battery and amplify it to 24V?
Old 04-30-2016, 12:43 PM
  #272
Mackhack's Avatar
2 x 12V and you got your 24 V. Problem will be that the rest of your car won't work anymore bc it blows up but hey you got your 24V pump going
But on a serious note: I'm sure the specs read it can operate between 12-24V and not 12 or 24 V.
Old 04-30-2016, 12:48 PM
  #273
MB-CLS500's Avatar
CL600 W216
on 12v it flow 25 gpm and 29 on 24v thought i could squeeze 4 more has anybody here ever installed EMP pump on their mercs?
Old 04-30-2016, 01:53 PM
  #274
Welwynnick's Avatar
2006 S600
I believe the WP29 comes in either 12v or 24v versions; they're not multi-voltage.
Have you downloaded the manual? Lingenfelter are a lot of help with these pumps.
http://emp-corp.com/support/marketin...MarketingID=99
http://emp-corp.com/support/marketin...arketingID=107
Nick
Old 04-30-2016, 02:01 PM
  #275
MB-CLS500's Avatar
CL600 W216
Nick
I am about to buy this pump so it either 24v or 12v? on this one it says 24v on the back so I wont be able to make this pump work on my car? its w216 cl600
This is what I found on CTSowners forum
Quote : Stewart EMP WP29 Water Pump
Selling a used Stewart EMP WP29 Water Pump, 24v version with 1"inlet/outlet. Used it with 12v for about a month and it works great! Need to install a G-force intake which routes exactly where this pump is mounted and can't find anywhere else to easily mount, so my loss is your gain. Looking for $310 shipped, also comes with brand new Deutch connector. These retail for almost $500
Will be taken out today so i can post pics later on.
Attached Thumbnails Understanding Intercooling, Charge-Coolers, Heat Exchangers and Circulation Pumps-s-l500.jpg
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: Understanding Intercooling, Charge-Coolers, Heat Exchangers and Circulation Pumps
