M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Water and Oil temps
Old Apr 3, 2013 | 03:56 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Water and Oil temps
Please can you all report what kind of water and oil temps you all are seeing.
Oil 203F
Water 202F
Old Apr 4, 2013 | 08:18 AM
Welwynnick's Avatar
2006 S600
Wow, really? For water I see 185 F max, and 175 F when I'm dawdling around town.
That's only from the guage though.
EDIT: Correction - its the other way round - 185 going slowly and 175 at speed
Nick
Old Apr 4, 2013 | 10:43 AM
shardul's Avatar
any thoughs on what could be the issue for mine being a bit higher. Fan is working. No leaks in radiator, coolant level is OK
Old Apr 4, 2013 | 10:58 AM
Welwynnick's Avatar
2006 S600
Does it make any difference what the ambient temperature is, or your speed?
If not, it must be down to what the thermostat is doing.
I've been wondering about the thermostat on mine. I presume its ECU-controlled, as the temp goes up and down according to my driving.
Nick
Old Apr 4, 2013 | 01:37 PM
fisherman123's Avatar
04 S600 16 Honda
Please show me how
Hi all,
I am new here.I basically go straight to W220's area and never know this part exists on the forum. Anyway I 'll love to take some temperature reading of my car and report back but don't know how,could someone please show me how without using some fancy/sophisticate equipment? Thanks.
Mike
Old Apr 4, 2013 | 04:09 PM
shardul's Avatar
you can use a OBD2 scanner with the CAN bus live data feature to view the engine parameters.
Old Apr 5, 2013 | 08:05 AM
AMG-Driver's Avatar
SL65 R230
Aftermarket Heat-Exchanger in front of Water-Radiator, which is blocking the Air-Flow? ...
Old Apr 5, 2013 | 10:43 AM
shardul's Avatar
OK i forgot to mention the above mentioned temps are 90F ambient weather. When ambient temp is 55F the oil and water are in the 185 to 190 range
Old Apr 5, 2013 | 11:27 AM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
That is pretty close to what i see as well, slightly less for the most part. My oil temp light does not even stop blinking until it reaches ~180F.
Aaron
Old Apr 5, 2013 | 02:01 PM
04 S600 16 Honda
Thank you Shardul, I'll dig my cheap Bluetooth OBD2 out and hook that up to my phone to get a quick reading.
