M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
The ABC Suspension Thread
Old Jan 12, 2017 | 06:42 PM
  #76
S65AMGBLOUAWY's Avatar
2006 S65AMG
ABC Damper hose
Hey Nick, first I want to offer a huge Thank You for pulling all this together. I went through most of this info a few years ago when my Damper hose ruptured at the connection just after the metal line's 180 U-turn. I followed your advice and had a local shop make me a new hose and used a 10mm compression fitting to attach it. Worked like a charm. A few months later the hose just before the U-turn ruptured. While tearing everything apart again I decided to just get all new hoses from the dealer. Using the numbers from your diagram above, I replaced 215, 220, 260 and (from an earlier diagram) 90 (runs across to the passenger side shock tower). I tore the pump apart and replaced all the o-rings while I had it out of commission as well. Looking at my receipts, I bought all those hoses from the dealer in October 2015. A few days ago, the damper hose blew again. Same place as the first one, just after the u-turn. This time I'm just going to have a hydraulics shop make what I need. It will not only be cheaper, but if there are any future problems all I need to do is unscrew the rubber hose and screw on another one. Thank you again for all your contributions to this site.
Now for my question. Have you ever thought of getting rid of the 'damper' hose all together?
If I cut the metal line just above the first rubber section and attach the 10 mm compression fitting then just cap it off, do you think anything really bad could happen?
Part of me thinks that the engineers at MB had to have put it on there for some reason so just removing it can't be good, but I have now had this amazing machine on a tow truck 3 times because of this 'damper' aka 'catastrophic pressure release' hose. My wife and coworkers think I'm nuts for putting up with this. I keep telling them there just isn't anything else I'd rather drive, but I don't think they understand.
Old Jan 13, 2017 | 10:44 AM
  #77
Welwynnick's Avatar
2006 S600
Sorry to hear about all those problems. The damper hoses do seem to be particularly vulnerable. That might indicate they're bearing the brunt of the vibrations and oscillations in the pump's output, and sparing the rest of the system. So maybe it does serve an important purpose. Car manufacturers never fit anything unless they really need to.
Could it be that aftermarket hoses are more reliable than OEM? I think that's unlikely, though I can't deny that there's a theoretical opportunity to upgrade the hose assembly to one with a higher pressure rating.
Otherwise I think aftermarket compression-fit hoses are a good idea because you can easily replace a failed one.
It's a simple matter to get two repair sections made at a time, so you can hold a spare. (I have a few in the garage).
I think it's also a good idea to replace vulnerable hoses periodically, by way of preventative maintenance (though I was thinking in terms every five years, rather than every year!).
The W221 and other later models don't have a vibration damper hose - they just use an additional accumulator on the output of the pump itself. That seems like a good idea, but I'm not sure if it could be adopted for the W215/220.
Nick
Old Jan 13, 2017 | 06:35 PM
  #78
biker349's Avatar
cl600
nick, i was just about to bring up the new tandem abc pumps with the accumulator attached to them. i really think it's an upgrade and also was wondering if there is a way to adapt that to our older cars. i was also wondering if it would be beneficial to add an accumulator fitting to the old dead end hose and what if any benefits it would serve. from what i've been able to find out is i believe the newer pumps put out more pressure and have a different part # than our older ones. don't know if they can be retrofitted to the older cars, but good fodder for thought.
the best,
Old Jan 13, 2017 | 07:03 PM
  #79
Welwynnick's Avatar
2006 S600
There are lots of different ABC pump part numbers, but I suspect they're all the same core, with different mechanical interfaces (like auto gearboxes).
The interfaces are things like pulley, mounting, inputs, outputs, etc, which are different to meet the geometry of the hoses in each particular engine and chassis combination.
If you could find a way to put an accumulator on the output of a W220 pump instead of the damper hose, I think that would be a good solution. I don't see any downsides to adding an accumulator.
Whether you could simply fit a W221 pump on a W220, I don't know. The pressure regulator and the feed hose is configured differently, so that pump will probably have a different output. There's probably a way. I'll buy a beer for the man who can.
Nick
Old Jan 16, 2017 | 11:08 AM
  #80
ki5yk's Avatar
'03 SLK320 / '03 S600
The damper hose is called a "Helmholtz Resonator". They are used to attenuate the noise/vibration from the pulsating pressure caused by the ABC pump.
There is a fair amount of technical info on the web about their function and design.
I would not recommend removing the damper, as it would introduce additional pulsation stresses in the hydraulic system.
There is a fairly lengthy section on them in the "Bosch Automotive Handbook" - interesting because many of the higher-tech systems in the W220 are included in this design book.
Regards,
Old Feb 13, 2017 | 10:56 AM
  #81
2006 S65AMG
Is there a particular version of the Bosch Automotive Handbook that you are referring to?
Old Feb 27, 2017 | 11:45 PM
  #82
2006 S65AMG
Fixed! Sort of.
Well, the lines have been repaired. I upgraded the rubber hoses. Went with something that should stand up to the elements better, and they are rated at 350 bar. Now I'm getting this growling noise from up front near the pump.
When my first line ruptured at the beginning of this ordeal, I was merging onto the interstate. I drove for 1 to 2 minutes before getting to a good place to stop and shut down the engine. After replacing the failed line, I heard this growling noise and assumed I'd destroyed my pump. I ordered a rebuilt pump and installed it. Noise remains, unchanged. I haven't completely ruled out the pump, but I feel it's unlikely 2 pumps would make the same growling sound. The noise is definitely coming from a belt driven component as it follows the engine speed. Also it goes away if I remove the belt and start the engine.
The next problem is the front suspension is much slower to raise than the rear. The front creeps up and down over a minute or so. The rear rises and falls in a matter of 3 or 4 seconds. I imagine this problem is probably related to the growling noise, but I'm not certain. The noise remains unchanged while cycling the ride height.
I attached a pressure gauge to the end of the damper hose. My pressure is right at 200 bar while idling. Drops to 185 when raising suspension, but returns to 200 within a few seconds of the button push.
The fluid in the reservoir drops more than the dipstick indicates it should when the engine is running. Meaning its right on the upper line with the engine off, but when its running, its about 1/2 inch below the lower line. According to Darren's excellent write up on the blogspot site, the more the fluid drops the better. So maybe that isn't a problem.
I'm leaning towards the accumulator, but why would it be slow going down? It could be the valve block, but the right side and left side are both slow going up and down and they are controlled by different valves. It could be the pulsation damper causing the noise, but I replaced that about a year ago because of a different noise that turned out to be a loose bracket securing the metal line to the side of the engine block.
Since I do my own repairs removing and cleaning the valve blocks would be free, but will take longer than replacing the accumulator. The dealer quoted me about $200 for each accumulator, so they aren't going to break the bank, but I hate just throwing money at the problem. I enjoy trying to figure it out too much for that.
I'd love to hear any thoughts and suggestions you all have.
Old Feb 28, 2017 | 02:38 PM
  #83
Welwynnick's Avatar
2006 S600
Great work there.
If you have a growling noise when the belt is turning, it does point towards an accumulator. Does it sound like a transmission noise, that you can only hear from inside with the engine running and the doors closed? Mostly audible around 1 - 2000 rpm?
The more the fluid drops the better? No, that's not quite right. The fluid should drop from the upper mark to the lower mark when you start-up. If it drop either more or less than that, then that points to an accumulator as well. Its difficult to identify which one
without removing and poking them.
Good luck, Nick
Old Mar 1, 2017 | 05:52 PM
  #84
2006 S65AMG
It does sound a bit like a transmission noise. Oddly enough, it gets louder when I shift into reverse. I have no idea what that would have to do with the ABC system, but it happens. I can hear it from outside the car as well, but it's more noticeable from inside as you can't hear the engine as much. It seems to be louder when listening from underneath the car, but that could be as simple as the sound bouncing off the garage floor.
I picked up 2 accumulator from the dealer this afternoon. Ill let you know if they solve my issues.
Old Apr 22, 2017 | 04:12 PM
  #85
Simon Ray's Avatar
CL600, Transit Connect
I too had a growl just as you described.
New engine and transmission mounts were the answer.
The sound is still there, but much lower in amplitude, being barely audible in or out of the car.
I am assured by my indie that the pump is ok and normal.
YMMV
Old Jul 5, 2017 | 06:45 AM
  #86
abstar's Avatar
s600
Originally Posted by Welwynnick
Hello Ian,
There are several ways to tackle this, and your dealer isn't much help. "old and rare" is a bit weak. Its the same technology as used on the current S and CL.
Firstly, what's the actual problem? Is the car still drivable, does it have warning messages, or has the suspension collapsed, leaving it undriveable?
Secondly, do you want the dealer to fix this, or do you want to?
Thirdly, yes, you can definitely replace the pipe without removing the engine. Just lift the engine a few inches, or drop the front of the subframe a few inches.
Finally, do you want to replace the hose with a new one, or do you want to repair it? Either is fine.
Be aware that the pipe in question is two pipes, and there's a threaded union at the front right corner of the engine. Assuming you have a failed flexible hose joint, you will need to establish which one - the one that runs in front of the engine, or the one that runs behind it.
Also be aware that if the ABC fluid reservoir is empty, you must not start the engine, or the ABC tandem pump will be wrecked in short order. Its fairly expensive, difficult to fit and difficult to bleed.
Finally, can you confirm whether its hose 215 or 260 that's failed?
215 is part number 2203205272; 2203202672 or 2203203972, and runs from the pump to hose 260.
260 is part number 2203205572; 2203203272 or 2203204272, and runs from hose 215 to the pressure regulator/accumulator.
(They're often prefixed with an "A".)
Regards, Nick
hi nick
just searching through some threads on abc hose replacements as I'm in the process of replacing mine and the hose pictured as 215 is joined to metal pipe that is between the sump and engine sub frame how do you uncouple them ,and on another point to remove the banjo bolt holding the two pipes into the pump did you remove the a/c line that runs along side it any information would be appreciated
thanks
aurelio
Old Dec 4, 2017 | 11:32 PM
  #87
heilanpiper's Avatar
2000 S430
https://mbworld.org/forums/s-class-w...ml#post5493638
Drew, you're right on the money. Removing the fan and poly-V belt isn't difficult (you do have to take care) but I think its quite essential to getting adequate access down there.
The socket wrench was good advice, too. My trusty 1/2" wrench wouldn't even go in there. I have a decades-old 3/8 socket set, but the wrench has something like 40/48 teeth, and that's too coarse to ratchet in the space available. I went out and bought an expensive 72-tooth wrench. Its a pleasure to use and does the job perfectly. For anyone who wants to remove these pipes or the pump, I'd say plan a little further ahead than I did and buy a 72-tooth wrench online for a modest amount, and don't even think about proceeding until you've done so. Its a no brainer.
I got the burst vibration damper pipe out and went looking for spares or repairs. I didn't hold out much hope of avoiding spending hundreds at the dealer, until I found a hydraulics/pneumatics workshop a few miles from home. On the phone, they said don't repair hydraulic pipes, as used flexible hoses cannot be re-terminated, which is something to bear in mind. A new one sounded fine to me, so I went down there and had a good time looking at the guy's face as he tried to work out what he was looking at. It was a picture, until I explained what it did.
The bent-pipe fittings are Mercedes proprietary, so he couldn't make anything EXACTLY the same, but he did suggest cutting the end of the metal pipe, putting a compression fitting on the end, and adding a terminated flexible hose to replace the failed section. The termination would be removable, so as to bleed the pipe. Nice. He did that while I waited, and it only took a few minutes. This all proved the worth of getting the part into the hands of someone who knows what they're doing, and has done it every day for a long time.
I pushed my luck and picked his brains about hydraulics in general, and what Mercedes had done in this instance, and he was happy to chat for a while. It seems that there's nothing special about the hardware, the pipes are what they call two-wire (twin layers of steel braid within the rubber hoses) which is typical for run-of-the-mill hydraulics. These pipes and fittings typically run at 300 bar, with ABC at the low end of commercial hydraulic systems pressures. He gave me some O-rings to replace the slightly squashed ones that came out of the banjo fittings, but was quite confident that I could use cheap nitrile O-rings from a large box-set that he dipped into for all his other customers. Do a search for "419 piece O-ring set", and you find what he used.
There was nothing challenging about doing this repair, and even finding this workshop was easy. For anyone in the UK, the chain is called Hopespare, and I thoroughly recommend them. There are lots of workshops around, and it was all very painless compared to going to a dealer. Best of all, he only charged me £39, and this is what I got:
Attachment 370257
Nick
I have a W220.028 2002 S400cdi V8 common rail twin turbo diesel with ABC and I blew my original ABC pulsation dampening line and recently replaced it with a new updated one A2203203572 and it lasted about 3 weeks and started leaking. On the V8 cdi ABC pulsation dampening Line, it lacks the U turn and is the length of up to the U turn so much shorter.
I imported this vehicle myself from Germany and is now the one and only V8 cdi in North America. I now know how the ABC pulsation dampening Line gets destroyed prematurely. In British Columbia Canada, there is a fairly new highway with a really bad bump that gets the car some air and then lands hard and bottoms out hard. Highway 17 south at Highway 91 connector, the highway is build on boggy peat and is sinking. It takes several days after the initial shock on the dead end line and the shock hammers the end fitting and causes the fracture and eventually failure.
After the OE replacement failed after 3 weeks of use, my engineering mind got to work and I got my Hydraulic Line Shop called New-Line chop off my original damaged end and I decided to add 36” of replaceable hose to better absorb the shock. I’m driving in this configuration at the moment and the fix is working.
I have ordered up a rather spendy Enerpac ACL-21A hydraulic accumulator to the end of the dead ended hose to better absorb shock nasty shocks. I will follow up with pictures once I get it all together.
Old Jan 15, 2018 | 07:16 AM
  #88
Welwynnick's Avatar
2006 S600
Hi All,
I've previously stated that the strut top bush fix / mod only works on the W220/215 front struts, as it had appeared to me that the rear strut bushes are different. I may have spoken too soon.
I have lots of struts lying around, and had a few minutes to play yesterday. The rear strut is different to the front, but it is similar, and it also has a strut-top nut bush with a pair of 5mm holes, like the fronts.
However, the design is different, and the nut bush sits lower down, below the level of the strut top plate. When you consider the three upward-facing studs, it's not possible to undo the nut bush with a 35mm pin spanner, like you can with the fronts.
I had a play with one of my rear struts, and found that I was able to loosen one of my nut bushes by a few degrees using the pin spanner, but not all the way, due to the mounting studs fouling.
Therefore it may be possible to remove the nut bush completely using a fabricated pin socket tool, like some people have made earlier in this thread.
I've bought a 30mm socket to cut up, and try to remove the nut, and I'll let you know how I get on. I'm hopeful of being able to use the same mod on the rear struts.
Regards, Nick
Old Jan 18, 2018 | 06:28 PM
  #89
Welwynnick's Avatar
2006 S600
OK, it turns out you CAN rebuild the rear strut bush in the same way as the front. The strut top nut bushes look the same, and the top of the struts themselves look the same, but the rear strut bush is just much deeper.
It looks like you ought to be able to interchange the bushes, but on ABC cars the front bushes are wedged, while rears and airmatic strut bushes are straight.
I had a play with my car tonight, and it looks like you should be able to remove the bush nuts from inside the car with the wheels on the ground, which would be ideal, but it does look tricky due to the head-rests and the rear window. My silver S600 has 164k miles on it, and doesn't ride very well on broken surfaces.
Diagnosing worn rear bushes isn't as easy as the front, as the rear struts have some free travel before the springs hit their seats, which seems very peculiar indeed. The result is that when the car is jacked up, the wheel can be levered upwards quite easily, giving the impression that the bush is badly worn. However, that's just the spring.
The real way to tell is by pushing the wheel or brake DOWNWARDS, and seeing if the whole strut moves down a few mm. On my car they did, so I'm definitely doing the job, and very much looking forwards to it.
Wish I'd figured this a long time ago.
Nick
Old Jan 22, 2018 | 07:28 AM
  #90
Welwynnick's Avatar
2006 S600
Hi All, I bought my first (silver) S600TT in 2012, and spent the first five years putting everything right (plus a few modifications).
It never rode very well, and I always missed my last S600TT, which handled difficult roads better. The front strut bush modification three years ago was a big step forwards, but it still drove like a bag of bones, especially in comparison with my second (black) S600TT, which has 30k fewer miles, and drives much better.
However, I finally replaced the left rear strut top bush yesterday. I used my home-made two-pin socket and an electric impact driver, and the nut came off easily.I cut off the old rubber bush, which was quite thin, and fitted a new 10mm thick bush.
I drove it to work today, and it was like a different car – and that was just one new bush. I have 275/30/20 tires all round, so it’s never going to ride softly, but now it manages to resolve the road surface, without making it feel worse than it is.Before it used to crash and shake and wobble and oscillate down all but the smoothest roads.Now, the bumps come, the bumps go, and they’re forgotten. It feels imperious, more like a luxo-barge should be.I’m really looking forwards to fitting the other rear bush.
This seems to be a systematic, recurring problem with high-mileage W220’s, and I bet it affects a lot of other cars out there. It’s a really worthwhile fix.For the record, this is the procedure I used,and the order is very specific: While you have clean hands, inside car remove parcel shelf cover above strut top Disconnect ABC electrical connector
Loosen but not remove 3 strut mount bolts
Jack up car
Put on stands
Remove wheel
Remove wheel arch liner
Remove and support brake calliperRemove bolt between knuckle and Track Control Arm (push knuckle down to free bolt)Remove strut bottom bolt (push TCA down to free bolt)
Push TCA down with long lever
Push strut back, clear of TCA
Support strut bottom with trolley jack
Remove 3 strut top boltsLower strut and carefully manipulate to get access to top bush (don’t strain ABC hose) Drill through strut bush nut holes if necessary
Undo bush nut with special tool and impact driver
Cut off old bush
Fit new bush
Re-assemble in reverse orderNote that the strut should be reconnected to the TCA before the TCA is reconnected to the knuckle Alternatively, if you can remove the strut top bush nut from inside the car, so much the better!
BR, Nick
Old Jan 23, 2018 | 07:59 AM
  #91
Welwynnick's Avatar
2006 S600
Airmatic Strut:
ABC Strut:
I was wondering if ABC had similar issues to Airmatic regarding the top bush, so I had a look at some cut-away drawings of airmatic struts, and it looks like they have little in common, and we can't use airmatic strut top mount bushes instead of ABC ones.
With ABC, the bush bears the weight of the car, but on Airmatic, the air spring bears directly on the strut mounting, and only the damper is mounted with a bush. Therefore the bush doesn't carry the weight and won't suffer from our wear problems.
the Airmatic configuration is conceptually more like a traditional spring plus separate damper configuration, and noting like a MacPherson strut type, where the spring/damper is one unit. It seems to me that the latter configuration is increasingly popular. my guess is you can get away with a bigger and softer bush, because the damper is still damping the spring effectively, which it wouldn't be able to do effectively if it was mounted in a big, soft bush. this may be an argument for ABC riding better than Airmatic, though my observation is that Airmatic does ride very well.
I wonder which configuration Mercedes consider to be optimum?
Nick
Old Mar 8, 2018 | 11:00 PM
  #92
FxFormat's Avatar
SL 600
Just read this entire thread, i have a leak in my ABC lines and i've never thought about going to a hydraulic shop and have them chop and graft a new section in. My main leak seems to be a weeping leak not a spray, i don't know anything about ABC as i just got my car a couple days ago, it's some kind of return line, the ones that runs under the radiator and the fat rubber one that runs along side the subframe from side to side. I will eventually have to do the high pressure hose that goes under the transmission, and on the SL, i heard you have to pull the subframe and lift the engine to get that line out.
Old Mar 10, 2018 | 11:46 AM
  #93
Welwynnick's Avatar
2006 S600
One or the other!
Good luck,
Nick
Old Mar 11, 2018 | 02:57 PM
  #94
FxFormat's Avatar
SL 600
Nick, by any chance do you know the part numbers for these two lines? One goes to the high pressure line that snakes around the engine, and the other is just capped off...wtf..both trace back to the pump, this is on a 2005 SL 600..
Old Mar 28, 2018 | 08:04 PM
  #95
FxFormat's Avatar
SL 600
I replaced the high pressure expansion line today, man what a crappy job. I removed everything in the front end to get access to the banjo bolt, finally was able to fit a flex head with a very stubby 19mm socket on it to get it off. Getting back on is 100x harder since you have zero room, no visibility, and the pipes are so stiff that is blocked by the brackets and so on. What terrible engineering, at least find a good place to put the AC lines instead of right there infront of the banjo bolt
This is on an SL600, someone mentioned they had to remove the subframe to get the bolt out, that's not the case with this one, you can get access to it from the front if you feel around for it.
Old Nov 14, 2018 | 06:06 PM
  #96
Claitman Adrian's Avatar
Mercedes w216
ABC problem
Hello guys. I hope here i can find what is my problem, i have an Mercedes CL500 2011 and just when i drive a little aggressive or i take corners in high speed ABC mafunction ( with yellow ) appears on the display, the car is raising up and the suspension blocks, when i turn it off and start it again come back to normal. Please help.
Old Mar 10, 2019 | 03:54 PM
  #97
owenthered's Avatar
sl500
2004 sl500 raises rear instead of front after replacement of abc block
I didn't take a picture before disconnection of the old block so I dont know the routing.but it appears that fb2 outer port goes to front right side and fb1 goes to left front strut. the 2 top ports go to cooler lines and the one on the end seems like a check valve /temp sensor so the one near the black metal line needs to go to cooler. Even if i had FB1 and FB2 reversed, my issue is that i have the rear of the car going up when I press the button inside and before replacing this the front went up. I barely lifted the left tires off the ground so those 2 struts were fully expanded, and the right side was fully compressed during replacement. I have disconnected both batteries and tried to get a reset. The other thing is even though the reservoir is full, the top will not go down.
I switched 2 solenoid wires and it raised the left side of car. i switch all 4 connectors to solenoids and it raises the rear then car senses the rear is higher than the front and it levels out. I dont think it did that before I changed out the block and solenoids. The other thing is it spit some fluid out which could be air? When this is correct it will be draining power steering fluid completely and filling with the pentosin. my wiring harnesses are void of markings so I could use the actual 2 wire colors to each solenoid. They are yellow/gray, green/green, orange/orange and yellow/?. thanks in advance.
abc block front 2004 sl500
Old Mar 28, 2019 | 08:43 PM
  #98
Dank420's Avatar
S500 & S600
I have a w221 m275 s600 tt and ABC light red came on. I siphoned and replaced 2 liters of pentosin chf 11s and did rodeo and automatic leveling. ok for 1 day and then it started again. The pentosin was pretty dark and when I took the cap off to check fluid level it broke! I tried all the tests and now it said the level calibration was not successfully completed,
startup has not been successfully ended,
initial startup procedure not complete, perform initial startup operation calibration (B24/12 (ABC lateral acceleration sensor)
initial startup not complete perform load adjustment.
I do not see any leaks and it maintains height and the raise/lower button functions. Actuators? Also the plunger control shows no current on testing but it functions? Please help.
Thank you in advance.
Old Jun 10, 2019 | 03:39 PM
  #99
Hank Kingsley's Avatar
2005 S55 AMG
2005 S55 here. Getting intermittent Red warnings on the dash, Take to Shop, Drive Carefully.
But I looked under the hood and the ABC dipstick cap was loose. Could that cause those error messages? Does the system need to be sealed tightly?
Because it was completely loose and once I pushed it on properly and drove the car, I had no more Red messages.
Old Jun 11, 2019 | 03:45 AM
  #100
ZephTheChef's Avatar
2004 S600
You're in the wrong sub-forum for an S55, but I do realize this is probably one of the more appropriate threads to post in, and I'm assuming the ABC is laid out the same way so to answer the question NO, it does not need to be sealed tightly to operate, nor would the computer have any way of knowing that it wasn't, but it certainly should be sealed tightly to prevent contamination or fluid loss. Check your fluid level, etc. If everything looks good there then you're probably going to need to get a scanner on it and see what kind of faults it is storing relating to the ABC system and proceed with diagnostics from there.
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
