M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Blowoff Valve Question
Old Oct 6, 2018 | 04:47 AM
black-series's Avatar
Hallo,
How would you recognize whether the blowoff valve is not working properly? Does a bov upgrade benefit a tuned car under all circumstances or is a properly working oem valve equally capable?
Old Oct 8, 2018 | 04:32 PM
Welwynnick's Avatar
2006 S600
I had a failed blow-off valve some years ago.
The only symptom was a nasty surge and lurch when snapping the throttle shut during acceleration. I learned to drive around it, but it was annoying.
The stock valve does the job, and is cheap. I can't think of a bigger waste of money than an upgraded BOV.
Nick
Old Oct 8, 2018 | 04:34 PM
Thanks Nick!
Old Oct 8, 2018 | 04:55 PM
ItalianJoe1's Avatar
2003 CL 600
Yeah, I'm with Nick on this one, unless you really want the noise, there's no reason to upgrade. They are already on the turbo housing, can't possibly be any more efficiently positioned, and if you remove the airbox and run aftermarket intakes, you hear the stock ones plenty anyway. I hear them on my tune only car with the windows down.
Old Feb 3, 2020 | 12:52 AM
Fried Chicken's Avatar
2005 S500 Designo
Nick
I think I might have this, but even barely letting off the throttle at WOT causes this to happen.
Old Feb 4, 2020 | 09:00 AM
pmercury's Avatar
member
CL
then do this
https://mbworld.org/forums/m275-v12-...lves-m275.html
good luck !
Old Feb 4, 2020 | 12:17 PM
2005 S500 Designo
Originally Posted by pmercury
Thank you!
[edit]
I found a vacuum leak. The hose that goes to the air reservoir broke and/or came out. I stuffed a new piece of hose in there, but I think to do it properly I have to remove..... EVERYTHING GODDAMMIT THIS IS SUCH A PRINCESS ENGINE.
Old Feb 18, 2020 | 01:41 AM
j.rol's Avatar
2016 Mercedes-Benz C63 AMG Sedan
BOV for stock c63
Hey fellas i just got a c63 2016, and i was wondering if i am able to add bov's inside if the car is all stock or will it mess up the performance and engine ?
Old Feb 18, 2020 | 05:52 AM
pmercury's Avatar
member
CL
of course you can
Old Feb 19, 2020 | 05:01 AM
j.rol's Avatar
BOV for c63
What’s a good BOV to run on a stock c63 ? I was thinking either renntech or weistec.
Old Feb 19, 2020 | 04:37 PM
pmercury's Avatar
member
CL
both are fine and overpriced
Old Feb 19, 2020 | 05:29 PM
j.rol's Avatar
What about a Agency Power BOV ?
