Rubber bits found in oil pan
So... I had the sump pan off my 220k mile 600 this afternoon (it had cracked and was leaking).
The job went really well until I went to dispose the oil of the old sump and I noticed some hard solid chucks of rubber floating in the oil.
These were the largest bits but there's a fair amount still floating in the sump.
My first thought is the oil pump oil ring issue seen on e55ks, but wishful thinking has me hoping for another (considerably cheaper/easier to repair) answer.
Any ideas?
J
The O Ring I was thinking of in the M113 (0279973848) is different on the M275 (0279973948) and doesn't have the tab as shown with my debris.There is another O Ring showing on the oil pump, but with no pictures available I'm gonna order it and see if it has the tab.
Your explanation makes a lot of sense - Enough sense for me to consider the route of blissful ignorance (and maybe keeping my 220 that could act as a donor car for a LITTLE while longer, LOL
Lit her up... Sounded good. Go for test drive... Made it 100' when it quit. Cranked slowly. Towed back into the shop.
Borescope revealed that exhaust valves met pistons. Front main bearing had spun in it's bore. I always gave her Mobil-1 and changed on time. Jay and I had recently done one of those very amusing drives that included much savagery. Never got beyond pulling the timing cover. The dead lump went to the recycler last week. Replacement runs great. Burns no oil. It was a treat to replace.
I can't help but wonder if I'm but one of precious few who thrash it hard enough to find the weak spot. How is thrust handled with this crankshaft?
Let's be straight.... The majority of those who purchase these cars (new) are octogenarians who are loath to try out what she can do.
I'm good to my cars so far as maintenance and never thrash on her before the oil is to temperature but haven't managed 20,000 miles to a set of tires yet.... I also live in close enough proximity to roads that let me find the limiter with regularity. Soooo much more to life then good fuel economy!
