electrical contact extractor
Old May 28, 2005 | 04:57 PM
direk's Avatar
2001 SL500, 2001 CLK55
I am trying to remove the "speed dependant volume control lead" from the harness on the back of my Audio 10 CD head unit. I would like to EXTRACT the contact from the plastic plug housing, without damaging it. Any ideas?
Dirk
Old May 28, 2005 | 09:02 PM
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
Please post pictures of the connector, up close. Please show each side and end.
Old May 29, 2005 | 01:43 PM
direk's Avatar
pics of connector
here you go. I appreciate your help.
Attached Thumbnails electrical contact extractor-dscn0016.jpg   electrical contact extractor-dscn0018.jpg   electrical contact extractor-dscn0019_2.jpg
Old May 29, 2005 | 04:05 PM
SUNILP's Avatar
2015 E250D
extracting that contact requires a special 2 prong tool from the dealer. about 40 bucks. or if you can rig something yourself, it would be cheaper. you need to insert a prong on each side of the contact from the front and pull the wire back.
Old May 30, 2005 | 06:56 AM
wingless's Avatar
As always, Sunman is correct.
The attached image shows the openings that need to have a tool inserted. I usually use a very small jeweler's screwdriver, but any small probe may be inserted.
That releases the contact tangs, so the contact may be pulled out.
Old May 31, 2005 | 11:04 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Highly recommend the correct tool... it is $18 for the blade and $9 for the handle. You don't really NEED the handle... but $27 isn't too bad especially if you will use the tool in the future. It takes like one second with the tool... whereas I had a tough time getting connectors out using makeshift devices (precision screwdrivers, etc.).
Of course, pricing depends on your dealer... prices posted are list.
-s-
Old May 31, 2005 | 11:52 PM
SUNILP's Avatar
2015 E250D
I must have confused it with the SLK pin extractor
Old Jun 1, 2005 | 12:04 AM
direk's Avatar
disable speed dependent volume control
should I be looking to remove the lead from the head unit, OR can the speed dependent volume control be disabled in software at the head unit? thanks for the replies so far...
Dirk-
