Intermitant hard start
Any help?????
Rod
Drive on
Rod
Drive on
Rod
Drive on
Good luck, Geo.
Rod
Drive on
Any other ideas ?
Rod
Drive on
thanks
Rod
Drive on
fuel filter/regulator
fuel pump
Crank Position Sensor
Plugs
My cars symptons are , if it was a 70's carb car, that the engne seems to need "priming" with fuel.So logic tells me that either the fuel pump relay is slow or that if there was a relay ( I don't know if there is or isn't) to switch the injectors, this is slow or faulty.
Does anyone know if the injectors are switched electronically, if so, where is the switch/relay????.
ALSO< NOT A SINGLE FAULT CODE IS RECORDED IN THE DIAGNOSTICS
not definite that it is spark, but probably is as when she does start obvious smell of unburnt fuel in exhaust - thanks for your reply to this thread, where is throttle actuator and fuel pressure regulator situated???
Regards
james
I would start with a fuel pressure test at startup- at least eliminate that
Also, it should be noted that we are talking about a 96 here, the fuel system has morphed 4 times since then (not to mention the engine changing twice already on a 320): so what applies then, did not then, and still may not now, the HHT program on the SDS for these cars is the same as the original HHT we had back them- just inside the new spiffy laptop!!!
Rod
Drive on
As far as the cam sensor, I guess it's possible, but I've only replaced a couple in my whole career (usually because of a code).
Adaptations (both kinds) are the car adjusting it's internal map away from the centerline to perform better. If that makes any sense!! Think of 1 as perfect (or centerline)- the car realizes it is running a little rich, due to age, fuel quality, altitude, whatever, so it adjusts itself to .96 and rechecks itself. If the adaptaions go too far away from centerline, a code is set and the check engine light comes on. Sensor gear works the same, except it's looking for misfires, and doesn't want to flag every little engine vibration as a misfire. Hope that makes sense.
They are reset with an SDS machine from MB.
Rod
Drive on
