Engine Shut off Prob?
I got ML 500 2002 I just run into a problem, after driving a while like an hour the engine shut off automatically, and it restarts after leaving it off for an hour, took it to a shop they checked everything kept it for 3 days seems like everything is fine, but still i got the same engine shut off problem. please help, and when i put the hook up it takes less time to restart
cheapest place to start-ive seen ignition switches cause that problem ,
burned connectors at the fuel pump,also if your key has several other keys
attached to it, i have seen vehicles stall going over bumps as a result.
hope this helps
bay area tech -ryan
It's #5 in this diagram;http://www.detali.ru/cat/oem_mb2.asp...SGR=075&SGN=04
Held by one screw but a bit awkward to get to.
George.
