anyone knows the code that disable the ESP completly???and how
i saw it on fifth gear.....a guy works at MB disabled the ESP completly
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
The thread on this is located on a question about drifting .Just unplug the module and ignore the lights on the dash.Try it in a big empty lot,and watch the wheel spin ,you will break it loose!when you're done just plug back in and off you go.
All the usual disclaimers apply to this message
Try this, turn key to position 1, press the reset button on the cluster
3 times(or press and hold it). A screen should appear with your battery
voltage. Scroll through the menu with your steering wheel buttons and
you should find a screen where you can select ESP off for dynanometer
test.
test.
'02 S320L (W220)
test.
test.
Because it doesn't seem to work with me
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
test.
test.
