Need DIY info.............
Jeff
if the key you have orignially worked try the above. or you can order a coded key and tumbler from the dealer and try it. there should be no reason to replace all the tumblers in the car unless theft was involved.
if beating and twisting it does'nt work you are screwed. you wll have to try to beat out the pin that snaps out of the aluminum part of the steering lock into the steel part of the steering column bracket. it wont want to move because the key won't turn. and/or...break out the sawzall
Good luck. HTH
Sounds like the sawzall thing is what the tech at the dealer was talking about. Man, I dont have one of those. I have the bottom of the dash exposed and have removed the bolts that hold the steering column tight. Just trying to get the power plug undone is impossible. I cant get it out of the plug at the ign lock. I can see that I am going to have to tow this thing in and pay over $500.00 to get it fixed.....................
To make things worse, my wifes Explorer has a failed transmission too. Thats why she is driving my E420. Waiting on the transmission to be shipped to me. Thats about $1,000 just for a used tranny installed. Now add this expense...........Happy New Year to me!
Jeff
At this link you can pay ~$25 and subscribe to Mercedes' WIS for a day and printout as many repair procedures for your car as you want. There are also dealer technical bulletins, accessory installation bulletins, recalls, everything. While you're there, you'll be able to access EPC (electronic parts catalog) too.
Anything you find elsewhere that's a copy of this is a copyright violation.
Why you say? The technicality of this job is way over my head. Afterall it is part of a sophisticated anti-theft deterent system. The MB tech warned me that if I didnt do it right the first time I would need to buy these same parts again. (They have a lock-up protection built in.) In addition, I have since discovered, thru the printed instruction, that the steering lock mechanism needs to be removed and replaced also and its got to be cut-out of the steering column. The space to work in is no bigger than a breadbox. There is no short-cut to replacing this switch. Trust me, do not try this job unless your a true master tech or mechanic. I dont have the tools needed to remove/cut-out the steering lock and furthermore I dont want to make things worse by screwing something else up....................
This is one job that needs to be performed by the pros...........
Jeff
Jeff
Its not the job it was in the 70/80's. You've heard all the recent pilot news stuff, pilots falling asleep, fatigue, long hours, scheduling problems, etc..... They squeeze every minute of time they can out of us to be efficient. Its getting old if you ask me. I am 51 and its getting harder and harder to do this job as I get older. Living on the road just isnt what it used to be when I was a younger man. Short overnights and longer days with more flights. I would bet not all of the pilots go to 65. I believe that most of us will go earlier like 62 or 63..............at least I will.
Thats why I drive an older MB. Its paid for. No car payments. But some of the repairs like this one are making me rethink buying a newer one.........
Just another day in paradise............
Jeff
Jeff
No $$ for flying. Folks think it is a POC,, but don't realize the actual.
