Brake Pad Sensor Light-30 C230
When I tell a shop I ONLY want pads, they say they wont work on it!
Please advise!!!!
Also, I di not hear nay sqweaks or anything of the sort from the brakes so am baffled as to why this light came on. Can I turn it off myself because it is always on?
Please advise!!!!
BTW
Welcome to the forum
Today's rotors are thinner for lots of good technical reasons and 25K may indeed be their lifetime.
You can "search."
Please advise!!!!
STFF = use the search feature.... to be nice
That's pretty good mileage for needing brakes imo.I changed my fronts at around 16k the first time and I'm about ready for fronts again at 34k.I do like spirited driving.
So next time ask someone to measure the current thickness of the rotor, then look at the minimum allowed to determine replacement,, not just <we always do it this way>. Best of luck,, my guess is you have another 20,000 safe miles in the pads and at least 50,000 more on the rotors, but your measurements will give you the best data.
I've never gotten more than 30,000 miles from front rotors on an S-class. They're heavier of course, but 75,000 miles for front rotors on any Mercedes would be very unusual. Of course, driving style will make a big difference but MB rotors do tend to wear fairly quickly. If you trust your mechanic and he tells you the rotors mike out of spec you should let him replace them. Never machine a Mercedes rotor.
I agree style does. I drive my corvette on the track and went 75,000 miles before changing pads. Just have to learn how to drive the car,, not the brakes to make them last. My wife drives the 500. nuff said.
I've routinely changed pads without touching the rotors with no ill effects but these days you HAVE to check the rotor thickness to see if it's still within the wear limit.
