KEYLESS ENTRY LOCK DOESNT WORK FROM KEYPAD,ANY DIY ON REAR PAD REMOVAL? 03 CLK500
Old Jun 20, 2009 | 10:53 AM
jayh's Avatar
clk500 2003
i replaced the battery in the key, but the lock button doesnt work on both controllers i have..the unlock button works..the auto open and lock in the door handles work,keyless start etc... but i cannot lock from the keypad,,any ideas whats wrong?
went to change pads and they were in perfect shape...anyway to get rid of this break noise? its noisy like pads need replaced but there perfect,front and rears..dont grind or shake just starts making noise when ya stop
Old Jun 21, 2009 | 03:51 PM
BenzTech415's Avatar
91 300sel,97 S500, 95 525i
sounds like yu have a bad remote key. as for the brake noise, remove the pads and install antisqueal paste to the back off the pads(metal side) and along the sides where they touch the calipers. I live in Cleveland and we deal with this on a regular basis. MB brake paste is prefered but you can purchase some at local parts store.
Old Jun 21, 2009 | 03:54 PM
jayh's Avatar
clk500 2003
thanks man... as for the fob key..both keys are the same problem..could it be anythign else? seems strange both lock keys would quit working at same time..amy reprogramming needed or resynch maybe?
Old Jun 23, 2009 | 11:26 PM
mbtech76034's Avatar
99 Z28 camaro 6.0
is your rear windhisield tinted?
Old Jun 23, 2009 | 11:27 PM
jayh's Avatar
clk500 2003
no tint..just started happening the last month also
Old Jun 23, 2009 | 11:36 PM
99 Z28 camaro 6.0
pull batteries. make sure each one is above 3V's. thats generally the threshhold. if not you'll have to replace the antenna module. some people thinks the battery is okay cuz it starts the car but that's not the case. you're rellying on your radio freuency here
Old Jun 23, 2009 | 11:38 PM
jayh's Avatar
clk500 2003
they are both 3v and brand new..is that not correct?
Old Jun 23, 2009 | 11:41 PM
99 Z28 camaro 6.0
no that is fine. as long as you've never had aftermarket tint on rear window, i'd go after the antenna control module.
Old Jun 24, 2009 | 02:17 AM
jayh's Avatar
clk500 2003
this something i can do by myself? any diy instructions? thanks for all the help
Old Jun 28, 2009 | 07:40 PM
before you go tearing your headliner out i would check the #8, 7.5 amp fuse in the rear fuse box. if good check and see if you panic alarm works. could have shorted alarm siren, would cause both problems in adistion to vehicle not locking.
Old Jun 28, 2009 | 08:06 PM
jayh's Avatar
clk500 2003
i panic alarm doesnt work..ill chekc that fuse tomorrow and let ya know! thanks
