key not turning in ignition
Old Sep 8, 2009 | 03:58 PM
churchy's Avatar
c230 kompresser
Angry key not turning in ignition
went down 4 mot battery went dead now key will not turn put new battery on it has anyone had any problems like this before.
Cant even get ignition on to plug a diagonastic in to see what the problem is?
Can anyone help
Old Sep 8, 2009 | 04:59 PM
Star & Laurel's Avatar
C 350 Obsidian Black
What year car is this? Is it a smart key car? If it is the smartkey doesn't rely on battery power to communicate with Ignition switch. The battery in the car is in working condition right? Interior lights light up?
Old Sep 8, 2009 | 05:28 PM
churchy's Avatar
c230 kompresser
its a 98 r reg got new batt on it yea its the plastic type key
Old Sep 8, 2009 | 06:12 PM
TMAllison's Avatar
09' E320
Are you trying to jump it with another battery or did you install a brand new battery?
Sounds like DAS isn't recognising your key. That can be caused by many things; low voltage being one of the most common.
Can you test the batt voltage with a multimeter?
Old Sep 10, 2009 | 02:59 PM
churchy's Avatar
c230 kompresser
install brand new battery it will take sterring lock of ut will not turn
Old Sep 10, 2009 | 03:45 PM
TMAllison's Avatar
09' E320
Maybe else who understands more about DAS will chime in....sounds like the first part of the security handshake (retracting steering lock) required to initiate a start is being recognised.
Perhaps its a mechanical issue.....Try using two fingers to tighten the beauty ring around the ignition where the key is inserted.
Old Sep 25, 2009 | 08:00 PM
rbhre's Avatar
2000 mercedes c280
Well, I have slightly different set up (electronic key 2000 C280) but I have the same problem, car will not start. I did already spend money on brand new Crank Position Sensor and car will still not start however, everything else is working fine, radio, lights, it does unlock the steering wheel. I am going to replace spark plugs (still don’t know how to do it) and where there are located. Also, I was told about some really went bed. Anyhow, If anybody have any suggestion please advise. thanx
Old Sep 25, 2009 | 09:38 PM
TMAllison's Avatar
09' E320
Based on your tagging onto THIS post we will all assume that your key when inserted, unlocks the steering wheel, but won't turn to position 1 like the OP???
Or is your problem diferent?
Old Sep 26, 2009 | 12:00 PM
rbhre's Avatar
2000 mercedes c280
2000 c280 will not start.
After the key is inserted then I am able with no problem to turn it all the way to the position that should start the engine. Battery is fully charged, I can play radio, open or close the car with central lock. Everything is functional; this is where I have suspected Faulty Crank Position Sensor. After replacing the sensor problem has not been solved, engine will still not engage, car will not start. When I was replacing crank position sensor, I have observed interesting think, that the old sensor was covered with oil; is that normal? Or something else is happening here. Now, I would like to replace spark plugs, and perhaps some of relays that are responsible startup system in my car, can you please advice how to proceed? i don’t have the diagnostic scan tool available however, I don’t think it will help much since the car engine is not running, or maybe I am wrong. All this happen gradually, sometimes car would not start and then would engage with no problem. Two days ago, I came back home and since then I am dealing with the problem.
Old Sep 26, 2009 | 03:04 PM
TMAllison's Avatar
09' E320
Try shifting to Neutral. If it starts then its the NSS; don't leave it in park w/o using the emergency brake cause it might not really be in park and could roll away.
Spark plugs are not going to cause a no crank issue so forget about them.
Old Sep 27, 2009 | 01:35 AM
crug75hid's Avatar
04 Volvo s60RMT
This is like damping bush. Right now no idea how to check other than checking one by one. Go ahead!... I am interested hear from you the cause.
Old Oct 4, 2009 | 03:42 AM
churchy's Avatar
c230 kompresser
can any one eles help with this can u get a old key recoded or do you have to get new key i ant got master key ether so going to get price it key use to lock and unlock car but its not doing that ether .
Old Oct 22, 2009 | 02:55 PM
churchy's Avatar
c230 kompresser
still need help been told he lost the code after key being left in it . where cheap place to get key coded round swindon will key turn if battreys dead in the key
Old Oct 22, 2009 | 05:14 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by churchy
...will key turn if battreys dead in the key
Yes
.. where cheap place to get key coded round swindon ....
I would be surprised if anyone other than an MB dealer could code the key.
Old Oct 31, 2009 | 06:22 PM
churchy's Avatar
c230 kompresser
ok now i have got key to turn but it will not start some one was telling me about green and red light in mirror but mine ant got any lights in it .i have changed the battery in the key but its still not lockin and unlock the car
Old Aug 19, 2010 | 11:47 PM
328iBMW's Avatar
Black C320
I took the batteries out of my key fob and now my car werks perfectly. haha
A new key is on order.
