Engine miss firing
Old Mar 18, 2012 | 01:58 AM
Dan Morgan's Avatar
97 S420
Engine miss firing
My 97 S420 with 119 engine and 131K miles has me puzzled with a rough engine. I do not have a scanner, and the closest dealer is about 100 miles away. My engine light is on, and when it gets real rough it starts to flash for a short while. When I go to accelerate or go up a slight grade it gets worse. When sitting at a stop light with it in drive and foot on the gas it will get rough after about 30 seconds.
I pulled and replaced all the plugs and noted that non of them stood out as being darker or lighter than the rest. They did have a yellowish look that reminded me of something like possible light sulfer on the insulater. Not the light brown that I was expecting.
Would a MAF sensor cause symptoms like this? My first thought was a plug or coil, but with the plugs being even in looks I am wondering mixture control. Am I all wet?
Old Mar 18, 2012 | 09:08 AM
MB-Dude's Avatar
'96 SL600, '05 S55 AMG, '06 C230
Based on the symptoms, it could be any number of issues. Cleaning the MAF is fairly quick and easy, though I do not think it's that simple. But the problem could be fuel filter, weak fuel pump, a leaky valve in the fuel delivery system, etc. The spark plug color suggests a lean mixture or possibly contaminated fuel but then it could also be caused by the engine computer over-compensating for a different problem. IMHO. Not a lot to go on.
Cheers,
Jeff
Old Mar 31, 2012 | 10:51 PM
bahrendt's Avatar
1991 300SE
Since it is a 1997, it is equipped with the OBDII diagnostic plug under the drivers side dash. I would consider going to your local autozone or comparable parts store, they should be able to read the codes for free. Have them print them out then do a search for those codes. That would give you somewhere to start without having to take it all the way to the dealership.
Old Apr 4, 2012 | 03:13 PM
vettdvr's Avatar
03 E500 and Corvette
Yes. Read the codes publish and you will get more help. You can even buy a OBDII reader reasonable. If you live 100 miles away consider mail order one and use it. One use will save the cost of the reader.
The day mine arrived my diesel truck would not start. So I tried out my new reader. It told me the problem and a $4.00 part fixed it. Otherwise a $200 tow to dealer and $200 diagnostic, then parts/labor would would have been way more. I paid about $130 for my reader already paid off 3 times over.
Old Apr 21, 2012 | 09:40 AM
j21importer's Avatar
07 E63, 04 discovery
try to inspect the hose coming off of the air mass meter, they are common for spliting and causing a similar problem
Old Apr 22, 2012 | 01:38 AM
Dan Morgan's Avatar
97 S420
OK, thanks guys. You have given me alot to consider. I will try Auto Zone for the codes since I drive by there all the time. And yes, I think the system is fighting the mixture control based on how it feels. Could the O2 sensor also be a factor? I have heard that they should be replaced every 100K miles, and I am at 131K. I don't know if it has been done or not, I bought it at 126K. That was just a random thought I had the other day. i am still planning on getting the codes. Thanks for your input.
Old May 16, 2012 | 11:25 PM
Dan Morgan's Avatar
97 S420
OK, a little follow up. I took it to my local mechanic that had a reader for my car and it came up with a miss-fire on #5,#6, #7, as well as O2 sensor on that bank and a Code for the catalatic as well. My mechanic, swapped coils from left to right and the codes stayed the same except #7 moved to #8 and did not follow the coils. Plugs all looked ok too.
He came up with an idea that my catalatic might be plugged on that side causing excessive back pressure and messing with the mixture on these cylinders and O2 sensor on this bank.
Also note that the exhaust has always had a rich smell to me since I bought it about 4k miles ago.
Any thoughts?
Old Jun 9, 2012 | 12:10 AM
PelicanParts.com's Avatar
SPONSOR
Answer
He came up with an idea that my catalytic might be plugged on that side causing excessive back pressure and messing with the mixture on these cylinders and O2 sensor on this bank.
Any thoughts?
That is a classic fault code combination you get when the Mass Airflow Sensor fails.
roy@peachparts.com
Old Jun 9, 2012 | 10:51 AM
Dan Morgan's Avatar
97 S420
roy@peachparts.com
OK, I was thinking that may possible, but would it only be coding on one side? Since last posting, I took car into muffler shop to have the Catalatic converters checked, and they bore scoped them and found them coming apart. So now I am saving some dough to get them changed out. crossing fingers on outcome.
Old Jun 11, 2012 | 06:42 PM
SPONSOR
Hmm
OK, I was thinking that may possible, but would it only be coding on one side? Since last posting, I took car into muffler shop to have the Catalytic converters checked, and they bore scoped them and found them coming apart. So now I am saving some dough to get them changed out. crossing fingers on outcome.
The converter may be secondary or coincidental damage, but must be resolved before further diagnosis.
I did say classic, the random misfire on a single bank is a common symptom.
I hope you are lucky.
FYI:
A cheap scan tool.
http://www.google.com/products/catal...d=0CJ0BEPMCMAc
roy@peachparts.com
Old Jul 21, 2012 | 12:42 PM
Dan Morgan's Avatar
97 S420
OK, got the Cats changed and she is running great now with NO check engine lights. I think the cats were damaged by the bad coils that the car had when I bought it. By the time I changed them, the damage had been started and it just got worse and worse with time. The cats were causing mixture to be off, and that caused more damage to the cat..... Now I am driving happy !
