C Class (203) Tip
Key in Position 1 press and hold the left cluster knob for approx. 20 secs (until you hear a beep)
Turn key to position 2 and hit the PAGE down key on the steering wheel. (don't mistake this for the arrow down key) depending on where you where at when you started, you may have to hit page down a few times to bring up the correct "test mode" of the IC.
You will know it when you see it, it will have software version etc.. it will also have an accurate measuring reading of the oil in the crankcase. Make sure you run the car and get it hot, then let it sit for a few minutes (yes you may start the car with this screen on) After sitting on level ground for a few minutes you want of reading of about 7.3-7.5 if you are under/over this may trigger a low/high oil light on.
Hope this little tip helps you guys out.
-Mac
Will this work on the C-coupe also?
However, the baseline number appears to be different for the coupe.
Mine runs at 6.2 with engine off.
Try running the engine with this on if you're interested in oil level changes on a running engine.
FYI, first post here so please pardon any clumsy formatting.
As for the coupe, I personally never tried it in a coupe, but I think someone posted a reply stating it will. It should, same IC.
As for the levels. The 7.3-7.5 is correct when hot and been sitting a few. This translates to about 8 quarts of oil during an oil & filter change. This is for the US C240 and C320s. Again Both are the same. I don't know at what points it will cause a low oil level warning or high oil warning. But if you play around and happen to get one you will be able to note the reading at that time. But our rep told us to stick with those numbers.
It is neat to see how the motor sees oil levels during a road test.
-Mac
I tried this procedure. It works great. However, the readout on my C320 (2001) says:
OIL LEV.: 7.5 qts. (i.e. it actually says the unit of measure)
By quarts, I assume they mean "imperial" quarts, hence the conversion to 8 quarts actual, right?
BTW, you can start the engine in this mode and watch the level drop from 7.5 to 6.5, which makes sense. However, starting the engine in this mode appears to reset the car's main TRIP odometer to ZERO. No biggie, I guess.
P.S. This won't work on the CLK, Bob... The existance of Comand has nothing to do with this feature, which I understand is W203 FSS derived, only. This procedure is the same as for the "smokey burnouts for W203 owner's" thread some months ago. At that time, it was determined that it didn't work for CLK systems, so it shouldn't apply in this instance, either. (Time to consider upgrading to the new CLK, which will likely have it, along with a modern rack and pinion steering system.)
Any way, back to the oil. With conflicting information, what is the best one to use. Should I add more oil to get the easter egg screen to the 7.5; check the dipstick; or simply go by the computer check screen.
Regards,
John Cappuccilli
'02 230 Black/Black
Tele-Aid
6 disk cd
Add on C7 wheels
Future:
Pulley system
some sort of shift kit
upgraded speakers--when and if possible
John Cappuccilli
