Stealership says I need new rear brakes and rotors.
Old Jun 24, 2016 | 09:12 PM
1BLKAMG63's Avatar
2011 Mercedes S63 AMG
I took my car in for an oil change and system check. Dealership stated that I need a new rear brakes and rotors. I drive a S 63. And and I looked at the pads and rotors they seemed fine a little low but not on the verge of replacement . Can someone please take a look at these pictures and let me know this is my first AMG . Thank you all in advance for the help .
Rear outer pad. Drivers side.
Rotor lip rear. And rotor face.
Old Jun 24, 2016 | 11:28 PM
GLENN S.'s Avatar
mb, saab, acura, dodge
The pads look like 50 percent. Now with the lip on the rotor, they're probably at minimum thickness. I tell my customers, use up the pads & replace pads and rotors then.
Old Jun 24, 2016 | 11:45 PM
1BLKAMG63's Avatar
Thanks a lot Glenn. Really appreciate the reply. Helps a lot.
Old Jun 27, 2016 | 07:09 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
You don't measure mechanical wear out by the looks.
Get on slide caliper and give us numbers.
Pads are good down to 2 mm even less, rotors have min thickness stamped on them (usually on the smaller hub outer side).
Lips say nothing about rotor wear out. I had huge lips on my rotors, yet measurement show I still have 60% of rotors left.
Grind the lips off and good for another 100,000 miles.
OH if highly paid technician gave you quote on new brakes without showing the measurements, he has no qualifications to touch Mercedes.
Old Jun 27, 2016 | 10:31 PM
1BLKAMG63's Avatar
So is it possible to just replace pads and keep rotors until worn beyond use?
Old Jun 27, 2016 | 10:46 PM
GLENN S.'s Avatar
Yes, that's what someone probably has done. As long as rotors are thick enough, you can put pads on. I don't grind the lip off, it helps keep the rotor from warping. I chamfer the edges of the pads to help break in.
Old Jun 28, 2016 | 10:00 AM
1BLKAMG63's Avatar
Thank Again.
Old Jun 28, 2016 | 10:34 AM
GLENN S.'s Avatar
No problem, I hate to see people waste money when they don't have to. And it has nothing to do with dealerships. It's a common practice at a lot of repair places. The estimates I've seen over the years for Un- needed work is staggering!
Old Jul 22, 2016 | 08:59 AM
efzauner's Avatar
2005 C240 2011 R350
The brake wear sensors often go off early... On my R350 rear then gave a warning with almost 1/4 pad left.. Just cut the sensor wire and solder/twist together to simulate a good sensor. 6 months later I finally did change the pads and the disks at the same time.. will be good for many more years.
