722.9 Conductor Plate Replacement Not Accepted
The Shop Tech called me to ask some questions.
Turns out this particular car, an 04 wants not only the TCU replaced but the entire valve body. That's why I got locked out of the SDS SCN encoding process i had tried earlier. He showed me the screen. The car was requiring a valve body swap when changing the conductor plate.
So; my query is IF I can resolder the broken connections on my original board, Could you fool the main ECU into believing the replacement is the original? Or send the rebuilt virginized board back and buy a new MB blank with no guaranty it''ll still ask for a valve body. OR do I just just buy another valve body and just finish out coding of the replacement?
The tech was an MB rep and was going to put in a call to his old regional service rep he is friends with
This going to take some technical background searches.
Thanks for any replies
Fooling it is easy.. will the car drive properly is another issue
2.Company sold me the replacement NAG2 same as original
I think i know why the SDS system is asking for a plate/valve body. How would the TCU know the changed out valve body was a replacement or the original is my question? It has no electrical connection to the car, purely mechanical.
Knowing only small amount about programming it would make sense they built that 3 way junction at that point incase the SDS doesn't see error codes from the plate and/ or a later plate was tried.
So;
Plate is same Gen as original
Valve body was fine no issues
Original plate throwing constant Internal sensor/Turbine sensor error codes
New plate was stopped at C1519 / C15EF by SDS and aborted entire encoding
Shop erases all error codes and begins encoding only to be stopped at an SDS mandated decision junction
FWIW Neither chassis or trans codes on the car are listed in the onscreen replacement categories
Update:
I got a call from the tech and we reached a solution.
The MB regional Tech Supervisor confirmed the screen cap. It takes a Blank MB plate specifically for my VIN not just a virginized rebuilt even of the same generation
Hary
Then it's easy to read the scn and variant string!
If your rebuilt unit is of the same part number as the original
Then you can flash it and use the same scn coding. If not then buy a new valve body!
Situation has been remedied but thanks anyways
