ESP not sending electric current to SPS
Old Apr 11, 2020 | 05:06 AM
a32amg's Avatar
Camry 2.0, CLK320, SL350, SL63
One day my steering suddenly became stiff. After weeks of inspections and diagnostics, it is found that ESP module does not send electric current to SPS.
Here is more info:
- Steering rack and pump are tested to be fine
- Replaced steering solenoid valve (SPS), no use
- Using Xentry to check ESP values, it is found that ESP sends only 2~4 mA of current to SPS. This value does not change when we tried to activate or deactivate it.
- Checked connectivity from the connector that plugs to ESP to the connector of SPS. Connectivity is fine.
- No error code is stored. ESP module does not have any fault code.
We checked a couple other SLs, ESP constantly sends out around 600~800 mA of current to the SPS. So mine definitely has some problems.
Would it be that my ESP is faulty? But if it is, SPS should have detected that wrong current value is sent from ESP and hence should have reported some fault codes. It seems like my PML has been coded to be disabled. This is sooo weird.
Car is 2011 SL63.
Any advice is appreciated. Thanks in advance.
David
Old Apr 17, 2020 | 01:13 PM
Russell Ormerod's Avatar
not a merc
You just answered your own question.
PML must be coded to on, then it will supply current again.
PML is SPS
Old Apr 27, 2020 | 01:57 PM
a32amg's Avatar
hmm.. but my car was having speed sensitive steering and one day it was just gone
My ESP module was never touched. It must have the coding.
And now all the sudden it seems like the function is disabled.
Old Apr 28, 2020 | 02:55 PM
not a merc
It's not impossible that the coding changed for whatever reason, just program it back to ON. Then we see what the result is
Old Apr 28, 2020 | 05:41 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
When this happened..... I’m sure the ESP light came on, correct? What codes do you have?
Old Apr 28, 2020 | 05:51 PM
a32amg's Avatar
That's the weird part.
No warning light, no error code.
We have used Mercedes Xentry (which launches SDS) as well as 3rd party scanner to diagnose and no error or fault code is discovered.
SDS reports that ESP supplies 2~4mA of current to solenoid valve.
Old Apr 29, 2020 | 03:01 AM
not a merc
There won't be faults or light activation because the ecu is coded for no sps. Just code it back!
Old Jul 13, 2020 | 08:33 PM
sinusshephard's Avatar
2009 c300
How to reprogram
PML is SPS
How do you code it back on?
Old Apr 21, 2022 | 12:44 PM
Marcil802's Avatar
C300 2010 4matic
I have that problem myself,I changed my sensors, now I get yaw rate sensor code 😱
Old Mar 19, 2023 | 08:22 PM
Shelly-mohd's Avatar
W204 Benz c180
W204 C180 Benz
Hi, having the an issue with no power steering malfunctions, EBD, ABS, ESP incorporative and run road indicator incorporative.
Old Oct 24, 2023 | 01:28 PM
treymadz12's Avatar
Benz w204
Hie were you able to get a solution to this? having the same problem ...been a month now
Old Jun 1, 2025 | 05:12 PM
Ziggy246's Avatar
2008 E320 CDI
Any solution to this?
By chance? Anyone has a solution?
Old Jun 2, 2025 | 12:14 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by Ziggy246
By chance?
Do you understand what's happening ?
