When to service low-mileage CLK
Any MB tech guys (or CLK owners) have any advice on when to service a low-mileage 2004 CLK Cabriolet (209)? I took delivery last October, didn't use it during the winter (New Jersey), and have been using it pretty much every day since April- mostly highway driving about 26 miles roundtrip per day. So I have only 4600 miles on the car. I haven't had any problems with the car.
I will drive the car until November, and then will not use it during the winter. But it's unlikely that the service indicator will come on since the car will probably only have 6500 miles or so on it by November. I don't think it's wise to go 1 1/2 or 2 years on the original factory oil fill, so I'm wonderng what I should ask my dealer to do before I put the car away for the winter. And what about tire rotation?
Thanks,
Jason
At least change the oil once a year, so like do it right before going into storage would be a good point. The service indicator should count down when a year is almost up if it hasn't been serviced...
Let it go long enough, and it will come up that way.
I will drive the car until November, and then will not use it during the winter. ... wonderng what I should ask my dealer to do before I put the car away for the winter. And what about tire rotation?
Thanks,
Jason
Check battery electrolyte levels (plates will go bad if not completely submerged in acid) - if possible, don't lock car using the remote (use metal key) - the alarm will drain battery. If that isn't possible, a battery tender would be a good idea to avoid a dead battery.
Inflate the tires about 5 psi above recommended - check tire pressure at least monthly to maintain this / avoid flat spots on tires.
I would let the fuel level run low - the gas will lose its anti-knock properties (octane level) and when you're back to driving the car again, you can gas up with fresh fuel again.
Every two years is brake fluid flush
Every three years is coolant change
