Can faulty blind spot sensors cause vehicle to shut off while moving?
Dealer is not sure, they think its the blind spot sensor, however they work. Saying there is little corrosion there. They aren't 100% sure because there are no active codes. The only code were
P0463 - Fuel Level Sensor Circuit High Input
P0179 - Fuel Composition Sensor Circuit High Input
P2068 - Fuel Level Sensor B Circuit High Input
U0111 - Lost Communication with Battery Energy Control Module "A"
U0100 - Lost Communication with ECM/PCM 'A
U0168 - Lost Communication With Vehicle Security Control
P0627 - Fuel Pump 'A' Control Circuit/Open
P2539 - Low Pressure Fuel SYstem Sensor Circuit
P1CCF - Engine Fault Code (Maybe High Pressure Fuel Pump)
P2137 - Throttle/Pedal Position Sensor/Switch B/C Voltage Correlation
P2135 - Throttle/Pedal Position Sensor/Switch A/B Voltage Correlation
To cut the chase, you can simply disconnect both of these BlindSpot sensors to rule them out of the loop.
These sensors routinely go bad from moisture entering the unprotected harness connectors. It's super unlikely they are causing your limp mode because they are on a distinct CAN unrelated to ECU/TCU/LPFP powertrain.
Let's simply disconnect them for now to give all chances to the ECU to stop acting up on the open roads.
From there we can consider the laundry list of DTC's you have listed. Realise that almost ALL of these DTC's individually can trigger your limp mode
(BlindSpot is not listed as a fault, correct?)
Root cause: this list of DTC's is consistent with a severe ECU disruption. It's not one bad module, it's a specific VIP collection that went nuts.
You've got the pedal sensor, the noisy fuel pump module, ECU, Cluster, BCM...
70% chance under voltage plays a role in crashing CAN controls as evidenced by:
> U0111 - Lost Coms with Battery Control Module
> U0100 - Lost Coms with ECM/PCMAll of these faults are VIP errors.
What exactly is wrong... perhaps just the noisy wiring near the LPFP crashing SAM Coms related to BCM.
I'd focus on the live Voltage to witness ECU controls ALT without fault for extended period of run time (not just 20mn drive).
This defect may be exacerbated by low MAIN battery, though new Batt is not a fix for it.
Let's try to corner this.
If it was in limp mode wouldn’t I be able to at least keep the car at a certain speed?
The main battery was replaced about 1000km ago with MB battery.
2- New OEM battery is great but says nothing about proper starting/running VOLTAGE.
Float and and keep a close eye on ALT output.
Unruly computers can drain the Main drain battery both with engine stopped and while driving.
It's easily replaced (lasts 3-5 years), remove the cover, the mounting strap and the vent hose, disconnect the battery (CAREFULLY!), install a new battery, reconnect the wiring (CAREFULLY!), reconnect the vent hose, reinstall the mounting strap and cover. Make sure the mounting strap secures it tightly, don't want it bouncing around leading to early battery death. Absolutely easy to do by yourself and saves a ton of money. Just make sure to get a direct replacement battery with a vent. The vent is used in case the battery ruptures (unlikely) and vents corrosive fumes into your car. Best to put safety over convenience.
Hope this helps.
Hope this helps.
There are cheaper ways to do this, but avoid the 9V battery that plugs into a 12V cigarette lighter socket, unless you're sure the socket is active when the ignition is off.
found this https://www.youcanic.com/wiki/merced...rative-message
