ABS/ESP Lights - SAM Code
Old Mar 19, 2022 | 05:20 PM
Jackson139's Avatar
2020 C43
Hello All,
2018 GLE350 went in for a rim replacement (front passenger side) and replacement of the center console touch pad. Driving the car home from the dealership the dashboard lit up with ABS lights and other errors. Turn back to the dealer and we scanned...came back with the following issues...
Front SAM Code:
- C107D86 - circuit 54 implausible
ESP CU:
- C018300 Brake light short to ground
- C030A00 S9/1 brake lamp switch is implausible
We drove the vehicle with the diagnostic tools hooked up and it seems that the "High" switch is showing Actuated in the ESP when the brake pedal is not depressed and that is throwing the codes. "low" switch functions properly. Its intermittent but happens quickly once vehicle is started. Replaced the brake light switch and that did not correct the issue. We also removed the entire center console and tried to drive the car with all those disconnected and it did not correct the issue.
My hunch is something was wacked when the rim was replaced...any thoughts?
Thanks in advance.
Old Mar 20, 2022 | 04:37 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ESP got upset....
Originally Posted by Jackson139
Hello All,
Front SAM Code:
ESP CU:
Thanks in advance.
If you want to double-check your No1 suspicion: compare wheel speed sensor data under ESP.
I think the answer lies between SAM & ESP. I side with F-SAM driving ESP crazy with bad data... try to reboot this car with a 5mn battery disconnect.
> Searching for the hidden cause:
Then reset OBD then scan for a couple days driving cycles to see what's happening throughout your buses.
Look at ESP "live data" to see what bad input may be causing it to error out. ESP is a honest module built tough to be reliable, you can bank something external is the upsetting cause.
Follow the trail...
Old Mar 14, 2025 | 10:36 AM
14.5psi's Avatar
2014 E350 CDi 258hp Saloon
Hello All,
Front SAM Code:
ESP CU:
Thanks in advance.
Did you ever get to the bottom of this issue? I am having the same issue on my 2014 E350 BlueTec. Exact same error codes and same live data in Xentry.
I also checked the live data for SAMR and it is getting 10.5v when the brake is pressed and the CAN bus signal is changing to 'Actuated' when brake is pressed. There is a message in the live data for SAMR which states the Rear SAM "receives signal 'Brake light (circuit 54)' from control unit 'N47-5 (ESP, SPS [PML] and BAS control unit)". N47-5 is the ESP/ABS module on some MB's but my car has N30/4 (..I assume Xentry is just generalising and I can insert N30/4 where Xentry is saying N47-5).
Thanks in advance.
Old Mar 16, 2025 | 09:36 AM
JettaRed's Avatar
Veteran: Army
Nope, I would not assume N30/4 (ESP) is the same as N47-5. XENTRY is pretty good at calling things what they are. But I could be wrong.
That said, I would check the wheel speed sensor. The brake light switch seems to be working if the Rear SAM detects a change, but that doesn't meant it's not failing.
Beyond that, you may need to get a circuit diagram and start tracing wires looking for a bad connection or damaged wire.
Old Mar 16, 2025 | 10:06 AM
14.5psi's Avatar
Thanks.
I checked Starfinder and no sign of N47-5 for the W212.
I previously checked actual values for the wheel speed sensors and they all matched (notwithstanding small variance which is to be expected) and all were within their expected range. There are also no DTCs pointing to wheel speed sensors faults.
Would this rule out wheel speed sensors as being the culprit?
As for the brake light switch, I installed a new genuine one recently, to no avail. I also noted the one I removed was genuine with a production date in 2020 (my car is 2014). I since spoke with the previous owner by email who said this has been a longstanding issue and that he went to an auto electrician who charged him a fortune but didn’t actually fix it.
The wiring diagram shows the brake light switch going direct to the ESP module under the bonnet. Four wires, a power, ground, High signal and Low signal, I believe. See image attached. I assume it goes from the ESP module to the Rear SAM then.
When I check actual values for the Rear SAM it is registering when the brake is actuated, which tells me there is a signal going from the brake switch to the ESP module then to the Rear SAM.
But perhaps only one signal is needed for the Rear SAM (e.g., Low signal) and the issue is with the High signal. I am just guessing.
This image shows S9/1 brake light switch going direct to N30/4 ESP module:
Old Mar 16, 2025 | 10:18 AM
JettaRed's Avatar
Veteran: Army
Originally Posted by 14.5psi
...I previously checked actual values for the wheel speed sensors and they all matched (notwithstanding small variance which is to be expected) and all were within their expected range. There are also no DTCs pointing to wheel speed sensors faults.
Probably. I think you would have a code if there was a problem. Have you used the testing function in XENTRY for the ESP N30/4 module or the "Customer Complaint" function? (This is where XENTRY is superior to 3rd party scanners.)
...As for the brake light switch, I installed a new genuine one recently, to no avail. I also noted the one I removed was genuine with a production date in 2020 (my car is 2014). I since spoke with the previous owner by email who said this has been a longstanding issue and that he went to an auto electrician who charged him a fortune but didn’t actually fix it.
How nice.
Post your VIN and I will see what XENTRY Simulation does.
Old Mar 16, 2025 | 10:25 AM
JettaRed's Avatar
Veteran: Army
Have you generated a scan report from XENTRY? Among other things, it will identify the exact version of your modules. If so, what does it state for your ESP module?
Old Mar 16, 2025 | 10:27 AM
14.5psi's Avatar
Yes I have tried the Test feature. It wants be to plug in a piggyback connector between the loom and the ESP module to then test the voltage to various combinations of the pins in the diagram I posted (e.g., pin 30 to 6 should have > 10.5v with the brake actuated.
Problem is I don’t have that intermediate connector. I even tried running a test wire but cannot disassemble the connector going to the ESP module, presumably for safety reasons (i.e., it is not rebuildable).
I can PM you my VIN if you think you get dig further for me (?).
Old Mar 16, 2025 | 10:32 AM
14.5psi's Avatar
No, I haven’t. But the ESP module is ESP9_212 (i.e, this is the SMR/CBF file I use in DTS Monaco. I know there also long numerical hardware and software numbers too in Xentry when you access each ecu. I can grab them if helpful?
Old Mar 16, 2025 | 10:37 AM
JettaRed's Avatar
Veteran: Army
I guessed at your model based on choices for the 212 platform and came up with 212.025. Beyond that, I would still need the scan report from XENTRY to make sure all the other modules are selected correctly. The problem is in Simulation mode, There is no C107D86 code for the Front SAM, but the for the Rear SAM. And, at that, XENTRY says to ignore the code.
For the ESP module, There are no "C" faults listed or any that start with 0. I will keep looking.
Old Mar 16, 2025 | 10:41 AM
JettaRed's Avatar
Veteran: Army
BTW, do you have the XENTRY Simulation application on your computer?
On this screen, before you run any scans, select Customer Complaints on the left (car with exclamation mark). Follow the instructions.
Old Mar 16, 2025 | 10:46 AM
JettaRed's Avatar
Veteran: Army
Old Mar 16, 2025 | 10:49 AM
JettaRed's Avatar
Veteran: Army
These tests are pretty much pointing to wiring and connector problems. Have you had any water intrusion or damp carpet?
Old Mar 16, 2025 | 10:52 AM
JettaRed's Avatar
Veteran: Army
Here are the tests. I would do as many as you can. I was surprised to see Steering angle sensor, Yaw rate sensor, Brake vacuum sensor, etc. possibly affecting the brake lights.
Old Mar 16, 2025 | 11:06 AM
JettaRed's Avatar
Veteran: Army
This is the results of a simulated test for the right front wheel speed sensor based on the OP's rim replacement and possible damage to the tone ring (multipole ring) or wheel speed sensor.
Old Mar 16, 2025 | 11:50 AM
PAINTED GND POSTS ???
The diagram shows the Brake switch is actually a CAN sensor module directly connected to ESP but is causing faults... interesting!
So the input does not depend on SAM but ESP still complain it's faulty despite new sensor module.
Fault is with chassis side, causing sensor error!
What do we know does that very well ???
Painter GND!
Let's do some necessary GND post Maintenance:
  1. Disconnect both batteries
  2. Clean up the painted GND post (under hood + foot well)
  3. Power up chassis
  4. Reset faults
  5. Scan
If no improvements then...
Take the time to trace the diagram to identify exactly what GND post feeds your Brake sensor.
Hope this help cancel that built-in defect for ya.
> SHORTCUT step:
Only reboot maybe enough without any GND Cleaning. Then that would be totally variable voltage threshold related and not even painted GND.
