C230K crank but no start with water damage
Your perfect report only shows C1330 as a real active issue. The stored faults are secondary at this point.
I am not positive BAS/ESP fault can prevent starting the engine.
Now go ahead and use your excellent scanner to read live data stream of EIS: Ignition module, F-SAM and ECU.
Spend couple hours poking around well for odd status.
Your going to find a condition is not satisfied....
---> Brake SW ok ?
(we know it's cranking: sw ok)
Keep the battery well charged up. No need to crank while testing with your scanner data mode.
In addition comb ECU values:
fuel rail pressure
CKP sensor
++++ Mismatched F-SAM VIN +++
You know MB parts are coded.... make sure you used replacement parts are not causing "crank no-start" condition - This is related to MB DRIVE AUTHORIZATION.... to which I am not expert at hackin German security.
Remedy is as simple as coding mismatched fields.
You have perfect fuel and CKP so let's check on spark from the ECU.
Let's check your spark coils have power.
One of the SAM relay may be bad.
We ve.got to trace down why so close
MAF would not cause a "no start" condition.
What is the FUEL pressure ?
What are the fuel trims
What are the live faults on the whole chassis
What is the running voltage?
LTFT2 = 0.... " "
Fuel pressure 65psi is good news.
I dont know why your LTFT show up blank in particular and other ECU data are ok.
a lot of faults point to CAN-C disruption from there the other faults are tied to that or secondary.
The big questions are:
1-- what CAN-C VIP module is not working and impacting your whole CAN-C ??
2-- water damaged SAM has been replaced already ... is it really working now??
I just realized I didn't mention that I removed the brake boost for inspection due to the P2404, C1201, and C1330. I found water inside the brake booster and ordered a used one. I've been trying to troubleshoot shoot this running rough issue while waiting for the part to come in. Is it possible that the system is causing the car to run rough (limp mode) due to the ESP conditions? I did plug all the vacuum lines associated with the brake booster. I received the booster last night and will install it today.
(Needless to say don't drive without brakes: ESP + Booster).
Speaking of vacuum booster, you said you plugged the Big vacuum line, on the engine side, right?
Q?: vacuum booster and SAM where flooded... is it possible the ISM shifter Module attached to tranny side got swamped to? It can short CAN-C.
My nephew left the Sam cover and lid off and the brake booster hose off the entire time it sat 3 years. Needless to say the entire divers side floor board was soaked. I'm close to bringing this thing BACK TO LIFE!
Thanks for the help! I'll report back with the results.
CAN distribution bars are located right there too... these need to be in perfect shape and connectors as well.
Overall it sounds like this whole flood issue started with roof drains being plugged up by the funny rubber outlet. Double check roof drains !!
I'm pretty sure I found my running rough issue. After unplugging the ESP and there was no change I decide to perform a compression check and found no compression in cylinder number one.
And two thumbs up for finding a damaged Cyl. No1. For some reason these engines like to waste the cylinders nearest to their oil pump:
Such as #1+#4 or #1+#5.
Where to go from here is up to you??
Zero compression sounds like a rather extreme case.
Sometimes thicker oil helps piston rings seal but not from zero.
Leaky valves or bad pistons?
How did the crank pulley get spun ??
Now you can easily index your TDC Cyl#1 and position the crank before head installation so your valves don't kiss pistons.
Also check out this video.
