Differential Oil Change
Old Jun 21, 2025 | 10:21 PM
JettaRed's Avatar
Veteran: Army
I have 56,728 miles on my 2015 SL400 and decided to change out the rear differential oil. There’s no scheduled maintenance for doing that unless you have a limited slip differential. Mine is non-limited slip. To my surprise, the stuff that drained out looked like coffee (without cream and sugar). The stuff I put in was Castrol Syntrax Long Life 75W-90 and looked like golden honey.
Has anyone else change their rear differential oil and was it black?
Old Jun 22, 2025 | 02:27 AM
Chevota's Avatar
E550 Coupe 2wd (2016)
I haven't done a Benz but all those I did do looked like yours or worse.
Old Jun 22, 2025 | 03:08 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
mine came out pretty much yellow at 120k then again at 170k
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jun 22, 2025 | 04:10 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
I serviced my RWD Diff early about 40kMi and was surprised to find high-glitter mixed with factory fill.
Glad I was early... 45° California hills are tough on heavy chassis gears.
Oil looked fine but all loaded up... so I installed a neodymium magnetic plug to replace missing filtration.
currently running 75w-90 gear oil
currently running SAE:75w-90 gear oil
"Full synthetic" oil that means a cleaned up group-III distillate.
I wonder if we can get diff PAO oil ??
Diff needs high shear more than any extreme temp, diff not super hot
Old Jun 22, 2025 | 04:28 AM
I've seen Amsoil sells gear oil of interest for our application - I wonder if this diff oil is good or great ?
specs
all product specs lined up 👍
marketing
marketing
Amsoil "severe Gear" oil ...
this may keep my diff alive
Old Jun 22, 2025 | 06:11 AM
JettaRed's Avatar
Veteran: Army
Thanks everyone for the replies. I went ahead and changed out the diff oil in my C350, as well. I also had a fine shimmer in the oil in both cars, though the C350 with 134,803 miles did not appear to be as dark (wish I had taken a picture of that, as well).
I happened to have had the Castrol Syntrax in my garage. I had bought a couple of liters a few years ago and never got around to using it. It's hard to get any gear oil that is not GL5 or made for limited slip differentials. This fluid is specifically for non limited slip diffs. I'm not sure Castrol offers it under that name anymore. When looking at my past purchases on Amazon, it is now called Castrol Transmax Axle. The insane thing is that I paid $15.99 per quart in March 2022 and it is now over four times as much. WTH, over! Mine was produced in Germany. The new stuff just says manufactured in the EU. Interesting!
Do you think the fact that this meets some BMW specification will hurt my Mercedes?
Old Jun 22, 2025 | 06:35 AM
I believe "non slip diff" chemistry is tolerant of brass parts.
I could not find anything except compatible with "non-slip"
Diff oil needs to be "hypoid gear" rated not simply gearbox duty.
Old Jun 22, 2025 | 06:42 AM
JettaRed's Avatar
Veteran: Army
So, is GL-4 or GL-5 specified? (I may be getting confused with the lube required for my Audi TT with a 6-speed manual gearbox.)
Old Jun 22, 2025 | 06:57 AM
JettaRed's Avatar
Veteran: Army
I found this:
https://a.co/d/55YxNPP
Old Jun 22, 2025 | 07:12 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
When I recently did the rear diff in my 2013 E 63 with 73,000 miles, the fluid did come out rather dark. I assume it was the first time it had ever been done in the vehicle which I had picked up with 42,000 miles. I do believe and could be wrong, but the fluid used in my rear diff was green (fuchs?) to start so the fact that it was rather dark didn’t bother me. That’s when I discovered my rear leaking axle seal. I refilled it with some Valvoline Synthetic GL five and now the dealer will put in whatever they stock. No limited slip for me.
Old Jun 22, 2025 | 11:19 AM
PAO gear oil
Originally Posted by JettaRed
I found this:
This 1-gallon container seems great PAO-Ester lubricant for manual GEARBOX... just not for rear differential hypoid-gear application.
Old Jun 22, 2025 | 11:37 AM
JettaRed's Avatar
Veteran: Army
glad I didn’t order it. I think your Valvoline stuff is what I’ll be going to.
Old Jun 22, 2025 | 03:21 PM
SPONSOR
Theres some overlap with 75w90 transmission and gear oils, it depends on marketing but they can both carry the same ILSAC GL-4 GL-5 rating. There will always be metal in the oil, it's really not a huge deal, most of it comes out in the first 5000 miles and it sorta just stays in there. Everybodys use-case is different. My car barely sees hills at high temp, but I'm running the 75w90 severe gear which is a 100% synthetic formulation. I don't feel a difference but at least now I don't have to think about it.
Then you get into the oddball stuff like we put in Porsches like Mobil Delvac and Swepco due to their specific formulation and anti wear additives which are good for transaxles. An open diff car isn't exerting any serious pressure nor does it need a specific lubricity for use with LSD's so you can pretty much use any ol' 75w90.
__________________
Old Jun 22, 2025 | 03:58 PM
TimC300's Avatar
I had replaced my rear diff fluid a few years ago prior to finding out about all the Mercedes specs. At that time I had bought and used Syntrax long life 75W-90. Shortly after changing the rear, within a week, I found out about the MB specs. I then found a Febi brand fluid that has the proper MB spec printed on the bottle so replaced it again. I only had the Syntrax fluid in about a week but the car drove fine.
I forget where the Syntrax idea came from, I read it somewhere that it was good to use. I had to track it down and it wasnt cheap either.
When I did replace the rear diff fluid the first time I do remember thinking how good the old fluid looks, like it must have been recently replaced and I didnt even need to do it. I have no idea when or if that fluid was replaced prior, could have been replaced right before I bought the car. I forget exactly how the front diff fluid looked but I dont remember thinking it looked as good as the rear looked and glad I did it.
Didnt want to waste the Syntrax so I use it in the auger gearbox of my 1971 Ariens snowblower.
Old Jun 22, 2025 | 08:35 PM
JettaRed's Avatar
Veteran: Army
Thanks, Chris. I have some Mobil 1 Delvac 75W-90, but can't remember why I got it.
Old Jun 22, 2025 | 08:38 PM
JettaRed's Avatar
Veteran: Army
Thanks, Tim. Do you remember where you found the Febi stuff?
EDIT: Never mind. It's all over the place.
Old Jun 23, 2025 | 03:53 AM
Baltistyle's Avatar
There was the post mentioning great pricing at rmeuropean.
https://www.rmeuropean.com/Products/...36-V13046.aspx
Old Jun 23, 2025 | 05:17 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
Is 75w90 the recommended weight? I also have a 2025 SL400. Capacity is 1L? Is my diff nonslip?
Old Jun 24, 2025 | 12:01 AM
POST MORTEM SERVICE...
In the chapter "rear differential Sce" comes this inspection after neglected maintenance.
We get to look at bad pinion bearings and shaft bearings totally matured...
That shows that good oil chemistry and service are essential to limit glittery self-destruction.
1x Qt of oil goes along way to 50kMi Max!
There is no pump in there to circulate oil so lube chemistry has to be effective against frictions.
OEM oil limits results with mandatory service intervals.
> TIPS ARE...
PAO hypoid gear oil
timely service interval
don't repair parts, replace units!
Old Jun 24, 2025 | 01:41 AM
SPONSOR
I think its "235" spec lets you use dang near anything 75-90, 85-90, and 90 SAE was the last time I looked. The important part is that it's clean and synthetic so it handles the heat and pressure in the scenario that you decide to do 155mph uphill in the thing for 30 minutes straight. Mercedes specifications involve severe-use case scenarios like can your brakes stop from max speed in freezing weather, and can your oil not break down in the UAE on your G-Wagen driving in 115F weather, and will your air filter survive catching on fire.
Generally yes, 75-90 and 85-90 are the accepted viscosities for Mercedes passenger car differentials. The limited slip differentials are typically AMG cars and even then typically they would need to specifically be optioned with them in the past so if you had an SL55 or SL63 you'd have to check your VIN to see what your car was optioned with. Those use a specific Castrol Syntrax 75-140 with friction modifiers for 235.61, now superceded by Castrol TransMax 75-140. Again I'm leaving room for me to be incorrect here but thats what I'm told to order for said vehicles.
Liquimoly does not have the MB Approval for said items, but they will often have the matching BMW approval and the API GL5 standard which the Transmax/Syntrax also has so common sense says youre probably ok. Again a lot of these companies just buy Castrol base oil and blend it anyway. Amsoil does it with Mobil/Castrol according to my knowledge.
__________________
Old Jun 24, 2025 | 11:22 AM
JettaRed's Avatar
Veteran: Army
LOL! The start of that video reminds me of those Asian pimple-popping videos
Old Jun 25, 2025 | 09:32 AM
jaxslk's Avatar
2025 GLE 450, 2022 AMG GLE 53
Can confirm the Transmax for the AMG spec - The dealer just did a diff fluid change on my 2022 AMG GLE and used the Transmax - here is the bottle they used:
Old Jun 27, 2025 | 09:15 AM
TimC300's Avatar
Theres an online store IDparts https://www.idparts.com/febi-oil-hyp...5-p-15664.html i'll buy from. They deal with diesel vehicles but have the same various parts. Bought most of my transmission service parts here. They are located the next town over in MA and have free pick-up at there warehouse.
When I bought the Febi oil it was around $18/bottle but has gone up since. they have Fuchs also.
