95 S420 stalls after warming up.
Basically once the car warms up to operating temperature it stalls and is hard to restart. Works fine from cold. New radiator cap, thermostat and rad flushed has already been applied. Check engine light was already on. There is a connection stuck open that prevents use of a code reader. This was already a problem prior to over heating / hose fitting failure adventure.
Just looking for potential sources. Gasket failure already on the table as a possible cause.
Reply here or in original thread.
BTW. lean mixture is exactly known to cause high heat... the root of your head gasket failure.
Could the fuel pump need replacing?
Maybe a fuel additive would address the problem? Guess I could try this (probably needs a cleaning anyway).
The car had been sitting. I resurrected it and put 5K kilometers without a problem then just kind of blew a hose on my regular daily commute.
You will want to measure fuel pressure before considering parts.
Pressure regulator may be integrated or not...
Connections may be oxidized...
pump may be marginal
filter may be blocked off
Will talk to my neighbor about these possibilities. He is a retired mechanic who collects old cars as well. Might be as simple as a clogged filter. Will see if he has a way to measure fuel pressure.
Won't be surprised if it is multiple problems.
Chances are it is a combination of issues centered around fuel delivery.
Once low fuel pressure is validated, research what is causing it ( pump, filter, regulator, low voltage, ...)
This is a reasonably priced part. How complicated it is to replace?
Will add it to my potential list of causes when I contact the garage.
Right now the candidates are:
Failed head gasket.
Low Fuel pressure.
Failed Crankshaft Position Sensor
Thanks for your input.
Long story is in the W140 forum but basically the car overheated/blew a coolant part within 20 minutes of it starting one day (running at highway speed/RPM). Had worked without any temperature issues for the first 5,000 kilometers I drove it. Is very low kilometers for age (<150K) but had been sitting. Didn't do anything to engine other than change oil.
Try to prioritize diagnosis over swapping lucky parts and diagnosing afterwards.
Consider getting your old THERMOSTAT replaced and the radiator hot-side hose.
This will help renew most of the coolant mix.
Keep a close watch on engine temperature while this is known issue.
> Loose belt over bad water pump can help prevent proper coolant flow.
> MAYO... TERMINAL FAILURE :
During extreme pressure events, Mercedes engines can mix coolant and engine oil through heat exchanger timing covers seals to relief pressure.
Pay close attention to oil + coolant not creating a MAYO mix.
My mechanic indicated that the coolant was circulating properly.
A user in the other thread speculated it may be a Mass Air Flow sensor problem. These are very expensive where as the crankshaft position sensor is relatively cheap. How difficult is it to replace a crankshaft position sensor? I understand your point about just swapping parts. I have limited diagnostic abilities. I bought a code reader (pulse counter) over the internet but the lights are stuck on (a circuit fault in the system) and it will not flash codes. Have found a specialty garage in the city that I am thinking of flat bedding the car to for professional repair.
You need a Mercedes specialist not any generic shop. They will have the MB specific tool to read your chassis and understand what to do instead of swapping the most expensive parts.
Your '95 car is not OBDII compliant, it requires MB 38-pins access tool.
Troubleshooting computers is not a parts lotery. Absolutely zero need to guess when the ECU is already measuring everything.
A great many parts can cause your stalling yet only one is causing this.
ECU data will help sort things out: money well spent!
