Cold Air Intake
The member Advans has a K&N cold air intake installed on his ML500, with very good results. Im wondering If I can get the same from my ML55. If not that, then what about the normal 'drop in' K&N Filter?
Im looking all over for aftermarket ML55 parts, it is hard =/
What I recommend you do is just buy the K&N setup that’s probably the best. You can actually buy any setup as long as its made for a Mercedes it doesn’t have to be model specific but choose wisely. Have someone make a bracket unless you have then nerve and feel like drillin it yourself. And maybe find someone skilled enough to make a custom in closer. That’s your best bet. I think all the ML’s K&N filters fit on all models 163 even the 55. Mine fits prefect now and it’s made by Reactive.
Only time you need more fuel or better management of fuel is when you go forced induction.....ie......turbo or supercharger! Your PCM (computer) adapts to your driving style,outside temp,type of fuel....etc. Reprograming your PCM will gain some HP........but does not have to be done once you change your intake.........your PCM will adapt.(make sense?) Any extra and/or cooler air entering your engine will not hurt.....just help! Please refer to the E55 forums............many posts are there covering your questions and concerns.The only problem is...........AMG designed a wicked intake already..........most AMG owners went heat shield wrapped intakes with Green Filters............oh.......by the way...........ribs inside your airbox where put in to make the box strong...........some people remove those ribs for better airflow.Your call.
Your engine is a vacuum..........the more air you get in and out of your engine.....the more power you will gain. PERIOD
Your computer will certainly adjust as best it can but that doesn't mean it will be able to optimize the air/fuel spark curve to as good or better than stock.
Heat shield and colder air is a totally different story. If you can cool the air then by all means that is only a help! However, just b/c you have a heat shield and larger airflow does NOT guarantee better performance. Do some research and look at empirical data and you'll see the truth.
better flow of colder air helps.........pal.............does not hurt in any freaking way.Gain 5-10 hp? Maybe.......that would probably be the most on a already effective/efficent AMG intake.
YOUR post states he would LOSE HP. YOU NEED TO SEE THE TRUTH.
Maybe all you have seen is gains. And maybe you're talking about a dyno proven air intake specifically for the ML55. If so, great! Post up some dynos if you got em.
Good point though..........a "high flow" intake that consists of an open cone air filter sucking in hot engine air will at times (depending on underhood temp) will decrease HP. You might of seen some cases.......on different cars.......were INCREASED FLOW OF COLD AIR my take away HP. NOT CALLING YOU A LIAR.....................LIAR ( sorry...typo!)
Just kidding..........really.........just kidding :p
AMG55 has stated he has seen an increase in power and after seing the set up he has have decided the design of it seperates it enough from the engine heat. I on the other hand will use the green filters when the time comes, more people who own AMGs have found them to be better and give a better throttle response.
Now could we please stop this bickering...
I keep hearing about these green filters, what are they? and are they similar to K&N? and where to buy? I know a lot of questions but the sound of more performance without all the complications is what I'm looking for, bolt on and go fast!
But..............same engine as mine................E55 owners have been there and done that...............telling you all what some of us (w210 E55 owners) have done.....................................so just giving my .02.
My bad.............it really has different heads?............I thought all 5.5 engines are the same other than intake and exhaust.
W208 clk55 has 342 HP compared to my 349 HP due to exhaust
same engine........same heads........same intake!
What's the difference?
I dont know what other AMGs share similar engines we all share the same 5.5l engine block, different internals on them though
