WARNING/ Hydroplane in ML63
REMEMBER the Ratio of the width of the tires compared to the weight of the car.I have 20 inch Contis on my Range rover SC...they are 2 inches narrower each tire. The RR weighs about 1000 lbs. more.There is no hydroplaneing at safe speeds in that car.
The Ml63 however is a 5000lb. car with WAAAY more footprint...so the formula is the wider the tire the more apt to walking ontop of water than cutting through it, and with less weight, Fogetaboutit!.
Everyone knows that feeling of 60mph in the left lane in a downpour when the road cannot shed the water fast enough, when you hit ponded water your heart skips quickly....
That was the scenario at 30mph with these tires and what worse is the spray that is sent off goes far and wide but mostly comes back on the windscreen...Its a joke....you have to re adjust your driving habits immediatly in rain....
I would imagine it wont be a better choice on black ice either!
Small price to pay for owning such a beast!!!
Remember the TV commercial for the E55 a few years back, When the MONSTER lived under the hood of that car.....They should bring back that add with the ML now!
Phil
Thats a footprint on dry pavement.
Actually I ran 18" Blizzacks on the Cayenne t bo,
but the cayenne had summer tires stock and they were a tad narrower.
BTW. I cant find a car wash that these tires can fit through either.
Not complaining just stateing the facts
Phil
Phil
All cars will Hydroplane at a specific speed...The Ml63 tires are almost 2" wider per wheel....All that means in comparison to th Cayenne is that it starts to plane at a lower speed because the pressure per square inch on each tire will not slice through the water, it will float through it..
easiest anology is a step hull on a v bottom boat..the faster you go the more it rises or PLANES.
That extra 2" at each wheel equates to a whole extra 8" wide tire on the car.
Like I said the overall footprint here is in supercar territory.
295/40's are massive
Plus I have wider tires than that on my 911 (305's) and have never had a problem. So width alone does not necessarily cause hydroplaning. Perhaps MB went for max dry performance tires that don't do well in water.
Phil
Just sold my CTT with 20's and I am sure the foot print is much bigger
I Think!!!!
Anyway my CTT just squeezed into the track at the car wash...the ml rides up onto the 2 tubes that guide the wheels...so no auto car wash for the ML.
I Think!!!!
"Tire Width is the width of the tire measured in millimeters from sidewall to sidewall.
Aspect Ratio is the ratio of the height of the tire's cross-section to its width. On our example, 65 means that the height is equal to 65% of the tire's width."
So, your tire is about 3/4" wider than the tire on my Cayenne.
Phil
