Boost gauge w/ Kleemann
Wonder how one would approach installing a boost gauge in conjunction with the Kleemann S/C? Typically, one can tap into the intake manifold, but as the Kleemann replaces factory intake manifold, where else (if any) can a boost gauge be tapped?
TIA.
TIA.
Hank-
It couldnt be easier:
On the right front edge of the manifold (driving direction) there is a pressure tap for the FP reg. Use a tight fitting (4mm ID) rubber T fitting to replace the rubber hose already in that spot. Boom- you are ready to go.
Perfect rubber fitting from MBZ is: PN 111 078 00 81 (its a vacuum T from a 4 cylinder evap system).
Re: Boost gauge w/ Kleemann
TIA.
TIA.
We are sending the engine cover out today. Taped on the underside of the cover is one of the vacuum T's I mentioned. This is all you will need to tap into the pressure side of the SC system. The boost GGE will read VAC and BOOST so be sure to buy a GGE that reads both.
2011 GL450
TIA.
TIA.
I have a new boost gauge. I bought it to use on my S/C. But you know what happend with that! I'll let it go cheap. I can send a pic. I never used it. Let me know if your interested.
Timster
i installed this on a c230k, dont know if this helps.
http://www.csportcoupe.com/forums/sh...&threadid=1112
Re: Re: Boost gauge w/ Kleemann
Originally posted by KLEEMANN
Hank-
Hank-
CLS350
Brandon, I received the cover today! Thanks again for the favor! I will return it to you in a few weeks.
I think Hank is going to use it as a template for a Carbon Fiber version he is having made.
