Kliier rear brake upgrade for CL203- all MBZ parts.
In building our CL203 for competition we found an all factory way to get killer rear brakes. W210 E55 AMG rear rotors and calipers bolt directly to the W203 with no modifcations- period. Heres the stats:
W203:
10 7/8" rotor diameter
3/8" thick, non vented
2 1/4" x 1 3/4" pad
1 1/4" piston diameter
W210 AMG:
11 3/4" rotor diameter
7/8" thick, vented
2 3/8" x 2" pad
1 3/4" piston diameter
Buying the factory parts will cost you $1000 for everything- not quite as cool as a floating tuner brake set, but a nice alternative.
You see between name calling, throwing mud, making lies and generally being arrogant pains in the A*% we actually contribute to the forums knowledge base. Holy cow- theres nothing to sell in this thread!
Moderator!!!
Thanks for the info
BTW How does the Parking brake Work?..On My W210 its SHOES inside the rear rotors..and The C Coupe uses the same set up?Is The E55 Different than the Other W210s?
I Do Not Use My Parking Brake..But some people with a Stick Might need The Parking brake ..
The E55 W210 rears bolt right on- no mods at all, perfect fit. Clearence is fine, even with 17" wheels (16"s to I suppose but who uses them?).
The C230 Coupe does not have "SAAB" style parking brakes but the same mechanism as on all post 99 MBZ- internal shoes like the W210. All of it still works as standard.
PS- Send me that IC info will ya?
I Was Thinking about the Different ''Shoe '' Sizes..
Does the W210 use different e brake ''Shoe'' than the w203.Different Backing plate and Thicker shoes,Adjusters and Retaining Springs for The SHOES?
Sorry for the Confussion...I Dont have access to the EPC for The Info.And Most MB Parts People will say ..Ah...I Need a Vin # To Help you.
W210 AMG:
7/8" thick, vented
2 3/8" x 2" pad
Could you give us a parts list, numbers? Thank you KLEEMANN.
Thanks Brandon..For The Info!
Thanks for posting the numbers and everything. C32 brakes up front, E55's in the back, should be interesting. I'll have to save up for Brembos eventually.
While you're at it, is there a way to run cooling ducts to the front rotors?
Do you think cooling would be required/ help? (not for street use)
What brakes are you running up front (KLEEMANN's)?
Thanks again!
Have they been posted anywhere ?
W210 AMG:
7/8" thick, vented
2 3/8" x 2" pad
$1000
