Supercharge 2.8 liter 6
1983 280 SL
I've owned a couple of 280s over the years and have always marvelled at what a fine little engine the dual overhead cam six is that was made from 77 to around 85 or so. I've noticed that they now have become plentiful in the junkyards, so I was thinking of attempting to rebuild one with a supercharger and slip it into my 83 280SL. Has anyone in this forum had any experience supercharging or turbo charging this particular engine? I'd love to hear their experiences.
Too old for these guys. A lot of them probably didn't even know the M110 existed.
Good luck. That would certainly be interesting.
The M110 has actually been around in carburated format since the late sixties, I believe. Went all the way through the early '90's in the Galaendewagen.
209/W210 Estate /W211 modded by MBENZNL
Re: Supercharge 2.8 liter 6
Lots of older Mercedes..and Tech info!
1983 280 SL
dslbenz, I think it might be even older than that. I was watching a History Channel program on Mercedes race cars, and in one under the hood shot of a thirties model racer I distinctly observed the dual cam shaft hemi head setup. I tried to find some more info on it but there just isn't that much out there either on the net or in my local bookstore on technical details of the early race cars. Lots of pretty pictures, but no meat.
Mark, thatnks for the info, I'll check out the site.
1983 280 SL
That's why I love the engine. You can cruise at 80 mph and get 24 mpg while your doing it. My 280E sedan could hit 125. I got 450,000 miles out of it before I sent to the junk yard, and it wasn't running all that bad. The junk dealer probably changed the plug wires and drove it another 100,000. That's why I'm thinking that an engine that strong would be a good candidate for some old fashion american hot rodding. I believe it has a forged crank and pistons, and the hemi head as well - perfect for supercharging. My only worry is that the compression at 9:1 is too high. Otherwise, it looks like I could pull out the air box and mount a Paxton type supercharger there, and just plumb the supercharger into the air intake of the existing fuel injection.
2004 CLK320
...My only worry is that the compression at 9:1 is too high. Otherwise, it looks like I could pull out the air box and mount a Paxton type supercharger there, and just plumb the supercharger into the air intake of the existing fuel injection.
The largest issue with installing a blower is insuring adequate fuel delivery. It isn't the amount of air you force into the cylinders, it's the air AND FUEL that matters. The biggest enemy of a blown motor is a too-lean mixture; that guarantees detonation and eventually a destroyed motor. Getting the extra fuel with the extra air can be a problem, and it is usually most successfully cured with auxillary injectors located ahead of the throtle body. An easier solution, but not as good for highest power, is to use a fuel management unit along with a high pressure fuel pump to increase fuel delivery pressure to the stock injectors as boost increases.
There are several excellent books on the subject - my favorite is Supercharged! by Corkey Bell, ISBN 0-8376-168-1. Lots of good information there.
28, alternate, efi, engine, kirk, ltr, m110, mercedes, performance, racing, supercharge, supercharged, supercharging, v8, vining
