R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
HVAC blend door actuator replacement
Old Jun 15, 2025 | 01:43 PM
Chrome988's Avatar
2012 MB R350 Bluetec
My 2012 R350 bluetec has an issue:
1. The passenger side vents, rear, and front windshield vents will not blow HOT air.
2. The AC for ALL vents is cold and is perfect
3. The driver side HEAT is perfect
4. Blower fan is perfect, no issues.
So I am suspecting there is an issue with the blend door actuators. I would like to replace them. I see from eBay that they come in a package of 5 or 6. One of these must be the blend door actuator for the HEAT. Does anyone have instructions and information to help me replace the blend door actuator for heat?
Thank you.
Old Jun 20, 2025 | 06:21 AM
ghenry's Avatar
2008 R350, 2024 Subaru Legacy,2018 Chevy Colorado
I believe there are two blend actuators/motors.....left and right. They must be "learned" after being replaced using a diagnostic tool. I have replaced the left one on our R a few years back. Fairly easy job.
Left side is above accelerator pedal and right side is left upper passenger footwell.
Old Jun 20, 2025 | 07:10 AM
Chrome988's Avatar
Thank you for your reply.
Yes, I took the glove box off and could see a blend door actuator underneath the blower fan. Did you have the same symptoms as me? I wonder if replacing it will help fix my issue.
Old Jun 20, 2025 | 07:25 AM
ghenry's Avatar
A diagnostic tool that will cycle the actuators and test the ACC would be most helpful and keep you from throwing parts at the problem....failed temp sensors in the vent ducts will also give problems as you described.
Old Jun 20, 2025 | 01:59 PM
SantaClaw's Avatar
2012 Mercedes R-Class R350 CDI 265HP Long
I believe if you set it to max heat/cold it should override any issues with the temp sensors. So If you get heat/cold when temp is set to max or min temp, it would indicate a temp sensor issue.
I might be mistaken though.
Old Jun 25, 2025 | 01:15 PM
Chrome988's Avatar
Unfortunately, my mechanic says the heater core is likely faulty but it's a huge job. Does anyone have the instructions to replace the heater core?
Old Jun 25, 2025 | 01:49 PM
SantaClaw's Avatar
Is it leaking?
Usually, if it is just clogged, you can connect a hose to it, and pour a mixture of Hot water and dishwasher powder into it, let it cool down, and use a garden hose to flush out the crud.
Or follow a guide like this: https://www.cleaningbasic.com/how-to-clean-heater-core/
The heater core, is just a radiator. Are you referring to the whole heater box?
Old Sep 20, 2025 | 08:10 PM
Chrome988's Avatar
Update:
Issue solved.
1. Mechanic was about to replace the heater core, when he decided he would flush it out first.
2. Good on him to start with flushing, a HUGE amount of silicone based junk came out of the heater core. The silicone was blocking the heater core. He spent 1.5 hours properly cleaning the heater core. He verified that it was clean using an endoscope. Heat is back to perfect.
3. Mercedes installs a permanent silica gel bag in the coolant reservoir. It is embedded in it. Over time, this bag can breakdown and send silica particles all throughout the coolant system, and they love to lodge in the heater core for some reason.
I am happy to have heat back and hopefully others can also attempt flushing before jumping to replacement.
Old Jan 11, 2026 | 11:16 AM
Chrome988's Avatar
Update:
1. Heater core flush only fixed the heat temporarily for about 1-2 months
2. We decided to go ahead with full heater core replacement. An important note, we bought an aftermarket heater core from rockauto to save costs, but got screwed because the aftermarket heater core was incompatible with the factory heater core hoses. So we had to pay up for an OEM heater core (about $400 CAD), and then my mechanic undertook the herculean task, which was about 10-12 hours of labour.
3. I can confirm that heater core replacement has fixed the issue. There is heat in the front and back and both sides of the car now.
Update:
Issue solved.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
