Are xenon lights effective if installed on 96 S500 regular headlights?
so, if i install xenons, will they be clear & bright on the road? will they cause glare or blind other drivers?
Did Mercedes or any other OEM make headlights with projectors especially for W140? (and i don't mean the cheap Made in Taiwan headlights).
Xenons lamps = Unnecessary glare
Personally I see better while using regular lamps, the yellow light reflects perfectly on the road increasing visibility rate way more than xenon lamps, only downside they don't look cool.
If you like to add xenon lamps to your car I suggest installing them in the front fog lights since you can turn them on/off like you desire while still having regular low beam.
while it is true, yellow allows you to see more in dense fog situations, in normal driving situations xenons produce light that is brighter illumating at 4300 kelvin.
light output is fantastic and much brighter than the oem setup in the s-class, and even in my ml500, and my 335i.
i used a set of audi s4 ballasts i got from a wreck for $100, and bought a pair of 4300k bulbs for $100.
maybe it is my eyes but I see better with regular lights installed in low beams in normal driving situations. Read JOZEF question carefully to understand why I suggested not using xenons in his low beam, his headlight are not projector type, if he installed xenons it will produce awful glare that will annoy other drivers, I don't know about others but I don't like to annoy other drivers with my xenons.
The oem reflector and lenses are not designed for the beam pattern of the HID's any more than the fog light buckets were not designed for them.
Blue light travels shorter distance anyway,thus the projectors.Why don't you build a set with projector lenses?Like the 210 guys do.
Or if you have a sedan with the H7 and H1 combo ,polish the outer lenses and install sterns 65watt H7 rally bulbs in the H7 spot and 55W Ultra High Efficacy Plus 50 in the H1 sockets.
Getting ready to do a diy article on using them in a W210 wagon That is going to a Midwest forum member.The W210 takes 4 H7's so he ought to have plenty of light.
I see that you a bit further away
Why do these guys with the blue lights keep blinding me?
youseffex,
The 2 of you are only 800Km away from each other. You ought to have a get together like we have stateside
at least if he/she puts them in the low beam area there are horiztonal and verticial screws he/she can adjust.
so again, your idea is stupid and doesn't make sense.
Repeat after me:
Fog lights and High beams are not the same thing.
Now go buy a new brain then go to sleep.
