S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
my 600sel won't start, help
Old Mar 20, 2004 | 06:48 PM
yaloha's Avatar
92' 600sel
hi guys, i just bought a 1992 600sel from auction, was driving it for few miles it was driving poorly, wors and wors every mile untill it stoped and did't want to drive anymore, i took it to a MB dealer they said its the engine wiring harness was bad and they said they can change the harness for $10.000 so i said thanks payed $350 for diagnosis, and i towed the car to my house, i replaced the engine harness, the air flow metters, air flow meter connectors with wires, fuel filter,,,, the car will not start,,, ones it sits for a day or so it will start for few seconds shake a little bit and stols and it won't start for few hours again, ones i crank the ignition i can smell fuel in the garage can it be fuel delivery??? i have no idea i know you guys know alot about cars, can someone help me???? thanks in advance, Jake
Old Mar 20, 2004 | 08:02 PM
barry S320V's Avatar
1995 S320V
600sel
yaloha: First of all where do you live. What is the name of the criminal organisation that tried to charge you $10,000 dollars to change the wireing harness? You should warn others of this place.
Second what did you pay for this car? It must have been almost free to buy without checking it out first.
Third who installed the parts you described? Does this person have any mechanical skill?
As to what may be wrong it could be many things. For instance is the engine timing set correctly, the car will not run no matter what you do if the timing is not correct.
Is there an independant mechanic/shop available to check the codes to determin what is realy wrong.
Don't give up however, it may be something as simple as a broken vacuum line, check all the plastic lines to make sure they are not broken or loose.
keep in touch , good luck
Barrry
Old Mar 20, 2004 | 08:59 PM
yaloha's Avatar
92' 600sel
well, I replaced the harness but it was nothing hard i just put all the plugs in the same place where the old ones went,, and i dont know if the timing is good, is there a way i can check the timing?
Old Mar 20, 2004 | 09:18 PM
yaloha's Avatar
92' 600sel
ok on the diagnosis there were few codes found, EA, CC, ISC CAN, MAF SENSON, "NO RECEPTION FROM LH1 AND LH2," thats what the diag said, of anyone has an idea what this is about please tell me , thanks
Old Mar 21, 2004 | 01:30 PM
guydewdney's Avatar
first off - get the codes cleared - and start afresh. most of those codes are prob from the old dead harness.
ignition amplifiers can go down like this - its the flat plate thing on the inner wings with a few big round plugs in it
350 dollars to do a diagnostic????
WHAT? jeeeez. its like 50 quid over here - you had better find yourself a new dealer.
also have a look at K6 JRF's S500 coupe site
http://pages.prodigy.net/jforgione/MB_S500.html
for tips on the earlier system
Old Mar 21, 2004 | 01:32 PM
guydewdney's Avatar
also look herer for a pdf copy of the data you need to access the codes.
taken from the autodata cd for the 1992 S600
www.dewdney.co.uk/guy/s600codes.pdf
Old Mar 21, 2004 | 04:05 PM
MB AMG's Avatar
2002 E55 AMG
Wow! Those are some high prices. Your 600SEL has that many problems!? Other than stalling and a little rough idle, mine is fine!
Old Mar 26, 2004 | 07:13 PM
yaloha's Avatar
92' 600sel
i just replaced the fuel pressure regulator and nothing, still smells gas when i crank the engine, and car starts for few seconds after coolong off for few hours,,, does anyone have any idea whats wrong??
Old Mar 26, 2004 | 07:27 PM
guydewdney's Avatar
another guess - if the engine is totally cold, does it have a secondaray injector to run as a chocke? if so - this is the oly one firing, and the normal ones arnt...
just a guess..
Old Mar 26, 2004 | 07:33 PM
yaloha's Avatar
92' 600sel
well what is that mean then, could u explain it to me little bit more?? thanks
Old Mar 26, 2004 | 07:43 PM
guydewdney's Avatar
on early sysstems, there is a secondary injector located in the intake maifold. when the engine is cold, it fires, creating a very rich mixture.
if this is the only thing firing, then the car would start and run for 30 seconds or so.
check the injectors (normal) have good voltage to ground / live
Guy
Old Mar 26, 2004 | 08:00 PM
yaloha's Avatar
92' 600sel
well when i take out the spark plugs the are wet, so don't the injectors work??
Old Mar 26, 2004 | 08:08 PM
guydewdney's Avatar
oh.... its a spark problem then, definately.
spark amplifier under the coil?
leads? ccap? dizzy? etc
Old Mar 26, 2004 | 08:19 PM
yaloha's Avatar
92' 600sel
i checked the sparks they make spark but i dont know if a good one, so can u tell me where the spark amlifier is located, and what i can do to see if its it, or if i can fix it, thanks
Old Mar 26, 2004 | 08:51 PM
1995 S320V
no start
might be your throttle controle module
Old Mar 26, 2004 | 08:56 PM
yaloha's Avatar
92' 600sel
but where can i find it and how can i fix it?
Old Mar 27, 2004 | 01:43 AM
yaloha's Avatar
92' 600sel
GUYDEWDNEY did you mean ignition coil???
Old Mar 27, 2004 | 02:40 PM
1995 S320V
yaloha
try this site. check option #9 for information on EA
http://pages.prodigy.net/jforgione/MB_s500.html
I may be wrong but I think some of the codes you got are to do with the electronic acellerator module.
Barry
Old Mar 27, 2004 | 03:03 PM
yaloha's Avatar
92' 600sel
u right berry, these are the codes i listed, but now what sould i do?? do u have any sugestion?? thanks
Old Mar 27, 2004 | 05:36 PM
1995 S320V
won't start
One of the things I would check before I put any more money out is to check the charge of the battery. A car with a seriously discharged battery will not run. Contrary to what is commonly believed, the cars charging system is not always able to recharge a very depleted battery, especialy if the battery is just too darn old to take a charge. hook up a good strong battery to your present battery with jumper cables, don't disconnect your present battery unless you have the radio code numbers or else your radio won't work until you get the code. Start the car and see if it will run with a good battery.
Recently my sons VW GTI kept dieing on his way to work. he would put the car on his charger and it would run again, then die. turned out his alternator was not working. replaced the alternator and everything is ok again.
Put some methyl hydrate in your gas tank just in case the fuel was contaminated with water.
Barry
Old Mar 30, 2004 | 01:26 AM
vinalf's Avatar
W140 600-SEL
Just wondering if the immobiliser is malfunctioning?
I have a 600 that did similar but my mech said it was the alarm/immobiliser and he re-wired it out of teh loop.
Old Mar 30, 2004 | 03:00 PM
yaloha's Avatar
92' 600sel
well i have no idea,, could u tell me what was happening with ur 600sel??
yaloha's Avatar
92' 600sel
and where is the imobilizer and how can i fix it , thanks
Old Mar 30, 2004 | 03:06 PM
guydewdney's Avatar
may I politly suggest that you do not have the knowledge or expertise to be able to fix a car like this.
I have 15 years of auto repair under my belt, and I'm scared by the idea of working on a 600 S class.
have you read the websites listed above? I suspect not.
I think you should just think about doing some overtime at work and paying someone else to fix it for you.
Old Mar 30, 2004 | 04:20 PM
1995 S320V
600sel
Guydewdney: I think you are right. most of us can do minor repairs if we work slowly and carefuly, however for complicated stuff I rely on well trained people. I am good at my job, but an amateur would make a mess of it. So I am willing to pay a pro to do the complicated work. I will not be taking out my own apendix for example.
Barry
