S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
W140 ASR limp mode
Old Sep 30, 2019 | 11:01 AM
Rod Thompson's Avatar
1995 S420 2011 C300
Angry W140 ASR limp mode
Hello everyone, so here is the deal on my 95 S420 which has had the wiring harness replaced is going into the limp mode still......where else should i be looking this is very frustrating I'm about ready to sell a lot of money has been spent so far other than this it runs perfectly . Is there anything else that could trigger this??
Old Oct 15, 2019 | 11:39 PM
Wrt1958's Avatar
2011 C300. 1995 S420
So no one has had this issue just wondering???
Old Oct 19, 2019 | 04:10 PM
Jdogali1989's Avatar
1992 500sel
Sorry to jump in but I suffer from the same thing. Im pin pointing it to either the throttlebody or the MAF at this point. My question hasn't been answered either. But If I find any more info ill report back
Old Oct 20, 2019 | 09:46 PM
Wrt1958's Avatar
I’m glad you jumped in interesting thing is the upper and lower harness has been changed, MAS has been replaced as well as the throttle body, just wondering what else oh and I have changed the fuses in the coffin..
Old Oct 21, 2019 | 01:21 AM
1992 500sel
Is it hard to start? How's your cps?
Old Oct 21, 2019 | 06:29 AM
Wrt1958's Avatar
Cos?
Old Oct 21, 2019 | 06:52 AM
1992 500sel
Cos?
Cam positioning sensor
Old Oct 21, 2019 | 08:43 PM
Wrt1958's Avatar
I have not have you replaced yours?
Old Oct 21, 2019 | 08:44 PM
Wrt1958's Avatar
Oh and no it’s not hard to start
Old Oct 23, 2019 | 07:54 AM
Gumboil's Avatar
W210
Did you have the vehicle scanned for error codes?
Old Oct 23, 2019 | 09:49 AM
Wrt1958's Avatar
Not yet...
Old Oct 23, 2019 | 10:53 AM
Gumboil's Avatar
W210
There is such alot that can cause a limp mode. Ask me, i know lol, stil lgot it. Anyway, low battery voltage, brake light switch, speed sensor, faulty accelerator pedal sensor or a bad transmission module. In my case it was a faulty transmission module, cause by oil going into the module. Your best bet is to have is scanned with a proper tool. Or else you going to be chasing your tail
Old Nov 13, 2019 | 05:51 PM
gwiz16's Avatar
95' S420
What is LIMP mode??
Old Nov 16, 2019 | 02:21 PM
Wrt1958's Avatar
So having your codes read helped pinpoint the issue?
Old Jan 12, 2020 | 01:17 PM
Wrt1958's Avatar
ASR sensor
I recently learned that the rear ASR sensor can also be a culprit in the limp mode problem that has been previously discussed.
Old Feb 11, 2020 | 02:49 PM
Ken Taub's Avatar
1995 S420
I may have a solution
I just found this forum five minutes ago. I had the same problem with my ‘95 S420 and was almost ready to get rid of it when the fifth mechanic to have a go at the problem solved it and it didn’t cost a fortune to fix. In an otherwise close to perfect rust free example, he found an internally corroded neutral safety switch. Once replaced, I have never fallen into limp mode again in almost three years and thirty thousand miles.
Old Feb 11, 2020 | 08:13 PM
Wrt1958's Avatar
Where is it located I would love to know how to find it and replace it
Old Feb 11, 2020 | 08:41 PM
Ken Taub's Avatar
1995 S420
Interior, under the right side dashboard, reached from under the dash. Sorry I can’t be more specific, but I wasn’t there when they did the switch. I was shown the old part, which is a small, fairly flat, plastic box. It is riveted closed. My mechanic popped the rivets and cleaned the internals of the part, re-installed it, and ran it for some time without going into limp mode. Then he replaced the part with a new one; just under $100, I think, but don’t hold me to it. Labor to diagnose was the bigger cost, but not crazy. That was in March of 2017. A couple of days later, we set off on an 11,000 mile cross country trip without being sure if it was fixed. I got more confident the longer I drove it. Never went into limp mode again.
BTW, before the repair, the car started and ran perfectly otherwise. My throttle body and harness had evidently been replaced before I bought it, and MB dealer I paid $200 for a diagnosis wanted to replace my throttle body (again, I guess) without guaranteeing it would solve my problem. Before the repair, it got to where I could get it to go into limp mode by accelerating hard, but it would also do it without slamming on the pedal. It got to where I could put the car in neutral, shut it off, and restart it all in the time it took my speed to drop from 70 to 50mph.
Old Feb 13, 2020 | 12:28 AM
Wrt1958's Avatar
That's a big help Ken I really appreciate it.....have had to do any transmission work on your?? Im the third owner of mines... It's smoked silver
Old Feb 13, 2020 | 08:36 AM
Ken Taub's Avatar
1995 S420
I found the bill. The part was $127, the labor to figure it out was $450.
I have had no transmission work nor have I changed the fluid. The only other unexpected repair was to replace a clogged catalytic converter when I first got the car.
Old Feb 13, 2020 | 09:39 AM
Wrt1958's Avatar
What color is yours and how many miles?? Mine’s had a 129K when I got it five years ago I know have 151k
Old Jun 2, 2020 | 10:52 AM
Bill Dosangh's Avatar
W140 S500 Limo
Where is the rear ASR sensor ??
Old Jun 22, 2020 | 12:26 PM
billydos's Avatar
S500 Limo
Hi what is a neutral safety switch
Old Jul 15, 2020 | 02:18 AM
Wrt1958's Avatar
There is one near the right rear tire
Old Jan 6, 2022 | 07:59 PM
RT_140's Avatar
S420
I have a 95 S420 with ASR as well. I start the car and the light is off. As soon as I accelerate, it jerks and then ASR light comes on. I haven't checked the CEL but is this how others ASR is as well?
