2001 S50O strange sound when turning
Old Mar 5, 2006 | 02:31 PM
Keyrat's Avatar
me: 2001 S500, 1993 K1500 wife: 2003 X5
When I turn left, my front right (passenger side wheel) is making a strange noise. This just started a couple of days ago and I wondered if anyone has any idea what it might be. I haven't heard any sound as I am going straight, it only occurs when I am turning.
Old Mar 5, 2006 | 03:13 PM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Wheel bearings, most probably
Old Mar 5, 2006 | 03:23 PM
Jayhawk's Avatar
S500/W220/2000
It could be dozens of things. I would run by your dealers and see what they say.
Old Mar 6, 2006 | 01:10 AM
Keyrat's Avatar
Smile
The noise only occurs when I am turning left and the noise is coming from the right wheel, when I turn right everything is okay and there is no noise. Based on this additional info., what do you think? Thanks for your input.
Old Mar 6, 2006 | 10:05 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Bearing, as mentioned. Possibe airmatic strut problem allowing wheel rubbing. Other problems too, as Jayhawk mentions. Have it looked at.
Old Mar 6, 2006 | 07:01 PM
MBZFAN55's Avatar
BMW M850i Gran Coupe
Can you duplicate the noise by also pushing the front end of the car up and down ? I can't recall all of the noises I had on my 2000 S430, but if I remember this one correctly, it was a failed ball joint.
Old Mar 9, 2006 | 01:07 AM
Keyrat's Avatar
Thank you all for your replies and suggestions. As soon as I get it checked out and diagnosed, I'll post the result.
Old Mar 9, 2006 | 10:53 AM
kenstudios's Avatar
This might sound primal but also check to make sure you lug nuts are tight. That can cause the wheel to act up when turning. That's just the first thing to check. The rest as mentioned above.
Old Mar 9, 2006 | 11:03 AM
esntrk1's Avatar
2000 S500
It's the lower ball joint.
Old Mar 11, 2006 | 02:02 PM
lx4life's Avatar
I had the same problem with one of my old cars, it was the cv joint. but i don't know the mechanics on these vehicles.
