Experiences with Retrofit Halogen (only) projector lights
http://cgi.ebay.com/ebaymotors/00-06...mZ110072655451
or these
http://cgi.ebay.com/ebaymotors/MERCE...QQcmdZViewItem
or these
http://cgi.ebay.com/ebaymotors/00-05...QQcmdZViewItem
or these
http://cgi.ebay.com/ebaymotors/00-03...QQcmdZViewItem
or these
or these
I found one person on another form that had and he took them off becuse he had problems with them. Anyone else?
You won't even need to have xenon reprograming with the way I wire the ballast.
Here's my car with the xenon retrofit, it was like flash light before the job. I'm sure those with the aftermarket W220 know what I mean
Another angle
And another
My headlight look
THis thread is really only about changing the Halogen lights to projector halegon lights for under one thousand dollars. However, if tyou think you can get OEM HID parts to work as a conversion for under one thousand dollars that would be great!
). Lot of othear headlight are as bright & sharp, just that Lexus projector design produce the widest beam. We're talking about Acura, Honda S2000, Porches, Audi ....In the HID retrofit world, guess which OEM part (most importantly, projector) rank near, or at bottom ? OEM Mercedes !!!
lens look and bought Depo manufactured units off Ebay. the light output
sucked. the lens/projector bowl design was mediocre. i put in Sylvania
Silverstars but that improved lighting by the barest of margins. the beam still
exhibited pie sliced, segments projected ahead of the vehicle. foreground light
was pitiful.
Zam indicated that the mount was spec-ed for near perfect, no-mod drop in using a bixenon from an E55. so I spent $200 to acquire these off Ebay and
slipped them in, bought Hella ballasts and D2S bulbs. It is now very decent
and a 3-fold improvement. Total cost was $850.
I have no firsthand experience with the units you've linked. their descriptions
are pretty sparse insofar as manuf, bulb size. projector size would help give
you an idea whether HID projectors could be retrofitted inside but you really
need to find someone who has a set which you can look inside and measure
spacing, opening, etc.
straight forward. but if you purchased HID projectors, and need help with your
project, am happy to try and help or look over your shoulder.
to your halogen base. i hold an extremely distasteful view of these one-size-
fits-all bulbs because they never calibrate them to the halogen light housing.
as such, their light output is poorly controlled and possesses glare which prove
unsafe to opposing drivers. If halogen bulbs display glare, their lower light
output is sometimes shrugged off by other drivers. But when the HID bulb
output is 3x brighter, it can be blindingly unsafe.
Most Ebay HIDs are HID kits for drop-in use with halogen designed light
fixtures...avg $250-500.
examples of typical HID kit output
http://i7.tinypic.com/2gx09l2.jpg
http://i15.tinypic.com/2ppeptx.jpg
http://i9.tinypic.com/4boasuo.jpg
HID kits fit a very profitable niche in the market, as it allows folks to go cheap
and get an HID lumen output into their car with few minutes of work. Most of
the time, as long as it looks bright, folks are satisfied. We drive classy rides.
Keep them classy with quality beam, I opine. HID retrofit only costs avg $800
The better answer is to take an HID projector (designed and has specs for HID
bulb, instead of halogen) and fit that into your headlight housing. That way,
you'll nearly always guarantee a precision beam instead of poorly focused.
HID projector into Depo light housing by Zam2000
Thanks Raymond G,
Now this is the information I was looking for.
After reading all this information in this focused discussion thread I have come to the conclusion that there is no substitute for the real (HID) thing.
I hope others will read this thread and stay clear of Projector conversion kits. Stay with the OEM projector lights that come with your car and wait until you get a new/used car with OEM HIDs.
Mark
I called my dealers parts and they could not tell if these were even an option or that there are OEM Halogen H7 type Projector clear lense head lights.
Does anyone know if these exist?
KENNETH04S and benznodubz,
Thanks for the info. However, wont this combination create very bad light. Atleast that is what others have said when using the 300 ebay specials. I know you are say to get the HID kit for them but wont they still throw off bad lighting?
KENNETH04S, I would realy like to see you pictures and links to where you bought your lights anf HID retor kit.
Mark
this out and eat it, then send you new lotto ticket from WA state.
again,99% of HID kits dropped into halogen projectors (and reflectors) produce
uncontrolled glare. penny wise, pound foolish. you may have Jessica Simpson
on your arm at a party, but just dont let her speak.
kenneth
