Congratulations!! Airmatic...visit workshop!!
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jan 29, 2007 | 05:09 PM
sprink49's Avatar
2004 S500
Just when life is returning to normal after hurricanes and the holidays, etc....today I get the dreaded Airmatic warning!! I just happened to be 10 min from Palm Beach Mercedes so I pulled in and had a service rep take a look.
"Everything seems to reset and clear sir...but it would be best to make an appointment for us to look into it". The best I could do is next Monday. I asked if there was any chance that I could experience complete failure based upon what we were seeing today. "Don't worry about it too much" he said "If it fails we'll send a tow truck." Oh goody I thought, now I feel so much better. So much for plans for a road trip this weekend. Stay tuned. BTW...I'm still under the original OEM warranty.
Old Jan 29, 2007 | 05:17 PM
newton22's Avatar
BMW E39
...And I thought the '04-'06 W220s were flawless.
You probably have a leak. If your ride height it still relatively the same, the leak is probably slow. If you have to drive it for the next few days, avoid bumpy surfaces and speed bumps at all costs (I don't recommend driving the vehicle until you can have it looked at).
For all we know, you're car will be slammed to the ground tomorrow morning. Good to hear it is still under warranty. I went through this whole Airmatic situation two years ago. Broke my wallet out of warranty.
Good luck sprink.
Old Jan 29, 2007 | 06:12 PM
sprink49's Avatar
2004 S500
Here is what happened: We went to the Dr.s office this afternoon. When I got out of the car I noticed that the compressor was running after shutting off and removing the key. I went in and came back out after about ten minutes and the pump had stopped running. I got in the car and started it and noticed that the height came up about an inch. Shut down again and went inside...compressor was not running. Left the Dr.s office, stopped for lunch...nothing remarkable. We left lunch and headed toward downtown to an appoitment. Suddenly I got the warning & drove directly to PBMB. While there the advisor put the "up & down" through it's paces and it seemed to work ok. Later when we got home I noticed that the ride height adjustment was not functioning. The firmness seems to work ok. I'm going to look for leaks...stay tuned.
Old Jan 29, 2007 | 07:21 PM
sprink49's Avatar
2004 S500
Meawhile...back at the ranch....I found fuse F32 (air compressor) had blown. R & R fuse from MB tool kit in trunk. Restart,all airmatic functions returned. Drove around the block, pulled into the garage, shut off and got out. The air pump was still running. After 2~3 minutes I opened the underhood fuse box and pulled the relay ("O" I think) and the pump stopped. I repeated this series of gymnastics with the same result twice. I think the relay is bad or I have a leak (maybe) because I keep hearing a large whoosh of air escaping when I shut the engine down. This is a new sound that I have not heard before. I'm going to call MB Palm Beach in the AM & see if I can sneak in and get a diagnosis. I'm guessing that there may be an electrical gremlin at the pump/controler if it's not the relay. Stay tuned.
Old Jan 29, 2007 | 08:20 PM
02S430's Avatar
W220 M113K
i needed my right rear airshock replaced, everything seemed normal, car when turned on it went up, ride height went up when the button was pressed, so it could be anything, goodluck
Old Jan 30, 2007 | 09:18 AM
Oxygen's Avatar
W220 S65 AMG
How did you diagnose that/how much did it cost?
Old Jan 30, 2007 | 09:38 AM
02S430's Avatar
W220 M113K
brought it to the stealer, total with tax was $1635 and yea thats right just 1 shock
Old Jan 30, 2007 | 10:26 AM
sprink49's Avatar
2004 S500
Update...can't get into the dealer untill next Monday but I made the appointment anyway. Meanwhile I swapped the 2: identical cross over relays in the front fuse box and every thing works fine!! MB dealer wants $59 for their relay so I called my wholesale bud who will have one this afternoon for $40. The MB part number is 0025421319 which crosses over to Bosch part No. 0986332040. I'll replace the one I swapped to the "N" location which controls the secondary air pump (probably controls some interior gizmo so I will replace it today) with the new one I am picking up later.
Ok...having said all of that the question comes up "why bother"? Answer, I need the car to be available and not sitting at the dealer for a week waiting on repairs. I'll take it in Monday for the scheduled appointment and let them check it out via the trouble codes in the computer. I think it's not a bad idea to have a spare airmatic relay on hand for us W220 guys ....just in case.
Old Jan 30, 2007 | 11:01 AM
02S430's Avatar
W220 M113K
yea i got one sitting in my center console, yea stealer wanted $59 so i bought it, and it wasnt the problem but owell what are you going to do
Old Jan 30, 2007 | 09:19 PM
sprink49's Avatar
2004 S500
Well...after driving around this evening after swaping relays......(drum roll) every thing works fine!!! Anyone up for a massive group buy on airmatic relays? I think every single one of us needs to have at least one as a spare. How many W220 owners do we have on this board? We might be able to get the price on these damn things down to under $20 each.If one of these things go's bad and you burn the airmatic pump out...in a very short time the vehicle will become totaly immovable. At least with a flat tire you could still drive on the rim. If you find yourself in BFE and this happens, a spare relay might be the only thing that gets you moving again. Food for thought.
Old Jan 30, 2007 | 10:24 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Good Idea..
I'm going to check that part number with some Bosh vendors I deal with to see how cheap that relay really is...
Old Jan 31, 2007 | 09:53 AM
srknutson's Avatar
2004 S500 & 2011 Mini JCW
I'm in on a group buy? How many miles were on the odometer when the relay failed?
Old Jan 31, 2007 | 10:30 AM
winmaw's Avatar
2000 S500, 2001 Camry,1996 Honda SUV
The dealer in NYC Manhattan MB sells slightly more than $20. I can't recall exact figure.
I replace once a year as a cheap maintenance.
Old Jan 31, 2007 | 11:45 AM
lionj's Avatar
Where on the 220 can I find the airmatic relay and where can i purchase one as a spare besides the stealership? Put me down for a group purchase. thanx guys
Old Jan 31, 2007 | 12:26 PM
sprink49's Avatar
2004 S500
Almost exactly 27000 miles.
Old Jan 31, 2007 | 12:29 PM
sprink49's Avatar
2004 S500
What's the name of the dealer? I'll contact their parts department and get them to send a few...I'll give them my Fed Ex No.....I just paid $42.60 tax inc. wholesale. Twenty bucks is the right number.
BTW...just spoke to a guy with a 2006 G500 from South Africa in the gas line at COSTCO. He said in the bush of Africa every body knows to have a couple of spare relays or you just might walk home...if you suvive the walk!!
Old Jan 31, 2007 | 01:47 PM
winmaw's Avatar
It is Mercedes-Benz of Manhattan.
Service Ph. 1800 515-3198.
Old Jan 31, 2007 | 03:32 PM
kor's Avatar
kor
MB S320CDI 2001, VW Golf Variant 2001, BMW E36 328I cabrio 1998
Beside lionj remark: how does one find all the MB partnumbers. And how can you find the location of it on the car. Is there a website or something for it?
Old Jan 31, 2007 | 06:15 PM
sprink49's Avatar
2004 S500
There is a fuse and relay list/chart in the tool kit in the trunk. It gives the location and type of fuse/relay and their respective function. You can call your dealer parts department to verify part numbers. The part numbers in this thread are for 2000~2006 W220 models (US).
Old Jan 31, 2007 | 06:49 PM
Singularity's Avatar
2005 S500 4matic
Exclamation
Pardon my interference but why someone who owns Geländewagen built on a rugged steel frame need spare airmatic relays??? Just out of curiousity.
It's really sad when airmatic goes. Since my friend owns a dealership in Russia I can see how often that happens on our bad roads. But I assure you of this. Bigger the rims, more sooner airmatic will go off. It's a mathematical fact. Just replace the tops upon hairy cracks appearance along with relay and you'll be fine.
Old Jan 31, 2007 | 07:28 PM
2005 S500 4matic
Exclamation
Once again pardon my cynicism. Signed in to provide you the info I originally wanted to share but stumbled upon this G500 airmatic relay blooper and forgot
Relay is only $16.50 over at Duval Motor Cars
http://www.trademotion.com/partlocat...?siteid=213951
Search for 0025421319 right where It says "2 Search by Factory Part Number" and there you go!
Old Jan 31, 2007 | 07:56 PM
sprink49's Avatar
2004 S500
[QUOTE=Singularity;1978978]Pardon my interference but why someone who owns Geländewagen built on a rugged steel frame need spare airmatic relays??? Just out of curiousity.
I don't know...I mentioned airmatic to the guy and he told me about why he keeps spare relays. Made sense to me. I guess the exposure for failure is not in the frame but in the relay.
Thanks for the heads up on Duval Motors. I'll check it out.
Old Feb 4, 2007 | 10:24 PM
sprink49's Avatar
2004 S500
I have a 7:30 AM appointment with the dealer in the morning. I've had no problems since I changed the relay. I'm going to put the bad relay in just before I take it in and let them code it out and see if any thing else comes up. I'll update when I know more.
Old Feb 5, 2007 | 06:39 AM
DRTYLNDY's Avatar
Does anyone here happen to know the OEM part number for the repair kits for the front airmatic struts? Any help would be great.
Johan
Old Feb 5, 2007 | 07:57 AM
Mark_K's Avatar
2002 S430
You are a bad person lol........
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
