Anyone Have This Stuck In Park Problem?
I removed the part and everything went well, I reconnected everything, and double checked.
So my problem now is that the car won't start... When I put the key in to start the car, the instrument panel comes on as I would expect, but the car won't crank. I suspected the battery, so I disconnected the battery cable and reconnected it. My car still wont crank. Does any one have any idea what else it might be? I tried my spare key but had no luck.
P.S. I tried to start it in both park and neutral
At least you will start at the beginning of any no crank problem and move down the diagnostic tree from step one. You can have dash lights,headlights,and still not have enough juice to turn it over.
I am going to google the "diagnostic tree" to figure out how to fix this. Thank you guys for all your help. Maybe I messed up the shifter cable getting the shifter out.
That is even if you suspect it is something else you always check the battery. Voltmeter or charge it.
Car has been sitting while you figured out the stuck in park problem. You think you solved that problem meanwhile the battery went dead and you keep chasing the problem thinking it is related to your stuck in park problem.
Start at the beginning eliminate the battery as the cause of the recent no crank problem and then continue with confidence that at least you have moved in the right direction.
It's like the guy who pays to have a T.V. repairman come to his house to fix the not working T.V. and the repairman reaches around back and plugs the cord into the socket
This morning I had a friend give me a jump, still no start!
I tried starting it in drive and in neutral.
Thank you guys for all your help...I can't wait to get back on the road again, playing music with my old friends...
You did use the same shifter, right? If you installed a new or other one, it must be programmed with the MB Star Diagnostic System. Keep us posted.
You guys are the best! I just can't thank you enough. I'll never go to the dealership again!!
See the merit in always starting out at the beginning of the Tree
I'm new to the forums and I've recently come across this issue. Does anyone know any reputable shops to get this issue fixed near Pasadena, CA?
Thank you guys for your help and time.
Kind Regards,
Pat
http://www.youtube.com/watch?v=AsxUF...eature=related
Sounds like you can't use your car and you need transportation. You can drive the car without the plastic part. The shifter will not lock nor require pressing the brake to shift out of park. Its a work around until you get the part. Just use the emergency brake when you park the car.
Follow the steps to repair, remove the plastic part and reinstall the shifter and center console. NOTE; make sure the key is off before you remove the shifter.
Would be one of the best auto shop expericence you have
How about an update. Doing so may help Forum members with similar problems. This is how we all learn.
[The shop said I had a cable by the shifter connected to the wrong port. It has run fine since then. Thanks everyone. I did not replace the pin.
Thanks once again, this thread is great!
