Switches above NAV not working
"It says that there is no data transfer between D2BMaster and a D2B Component. The Component at Location 0 reports a fault in the D2B ring."
Any idea what this is talking about?
I am begining to think technical help on this forum is a lost cause.
But if it was me and I didn't want to take it to the dealer, I'd pull them and look for a loose wire. Check for power and ground. That is after I made sure it wasn't a fuse or fusable link issue.
To understand the technical help provided, one needs to understand something about the car. The CarSoft info told you one thing that is wrong. The fiber optic ring has a component that is either malfunctioning or is disconnected from the bus (or has a damaged lead), and that is being reported by component 0, the fiber optic controller - in the '01 S500, that's the COMAND/radio unit. See the phone bulletins on Paul H. Dick's site at http://home.earthlink.net/~phdwebsit..._bulletins.htm - toward the end of it is a diagram of the components on the fiber optic bus. One of them, not necessarily the COMAND unit itself, has a problem.
There is also an extensive discussion, including an instructional tract on the D2B fiber optic bus that your brother's car has, on Paul's site.
I cannot tell if the reported malfunction will have impact on the switches because I don't believe they are on the fiber optic bus. Unfortunately, I don't know enough about how they are connected to other controllers.
However, you have spent some time on the forums - you can probably identify certain folks with a great deal of technical knowledge - between MBWorld and BenzWorld, there are Sunman, Streetglower, Diesel Benz to name just a few. There are more, and they are helpful. If you don't get a reply, perhaps e-mailing or sending a private message to one of them will get a response. You'll need to include the info on the car (year, model and some geographic info - US, European, Asian specs) and as much as you can about what symptoms are present.
Then, give them a little time to consult wiring diagrams, factory bulletins, and so forth. These folks work for a living - and they give of their spare time to try to help. They may actually have things to tend to besides your question.
And, when you get a technical reply, I hope you will comprehend it better than you did the CarSoft information.
Of course, if a response takes too long for people to provide free assistance, you (or your brother) can always take it to a dealer and pay the price for a faster response. A faster response is a maybe. Pay, a certainty.
I ended up removing all the trunk panels and rear seats to go through everything, but it all checked out fine. The car had some kind of aftermarket video system or something so I thought they may have damaged something.
I removed the COMMAND noticed the module behind it the dealer was talking about, that those switches connect to. All connections were fine. This is the one the dealer said was $90. I will replace this and see what it does, if not going to the dealer I guess. Although two dealers I talked to said they have never replaced one.
BBaller14 has also posted a fuse diagram for the '01 S500 here - http://www.benzworld.org/forums/w220...e-diagram.html
Since someone has modified your fiber optic loop with additional equipment, connecting power to the supplemental equipment may have damaged or accidentally disconnected the power source or ground to the module. I have never seen this particular problem reported - indicating that it isn't common. It was more likely caused by someone fooling around than by a manufacturing defect.
If you don't find a fuse, trace the power and ground sources from the module back to the fuse block and to the grounding point. Look especially for wire splices.
If that doesn't identify the problem, you're back to replacing the module.
Be sure you're not dealing with the airbag module (the one in my '05 is prominently labeled). And good luck.
As complicated as these cars can be..... always go back to what is logical....
Good job
Thanks, chibenz!
