01 S500 Catalytic Converter Problem
Old Jun 3, 2008 | 01:39 PM
fbaut15's Avatar
S500
Hey guys, I have this rattling noise and I know is the catalytic converter. I heard that there are places such as www.evosprt.com where you can buy the cat itself and have an exhaust system shop weld them for you rather than replacing the entire exhaust system as the stealership would like to do. Is there any truth to this notion, or any suggestions?
Old Jun 3, 2008 | 02:08 PM
AH1W-COBRA's Avatar
2003 S500, 03 C240, 03 E320, 03 tahoe
just get a quality match
do a search and look what the other members are buying.i know they refer to them as high flow cats,which wont make any difference in your application but it wont have any adverse effects either.if you have the $ replace them as a set.im guessing $160 each and $75 install.use a reputable shop that specializes in exhaust systems to do the install.see if they will cut the flanges off your old cats and attach to the new "universal fit" cats so that you can retain the bolt on application.ps' if your factory units are weld in than it will make it that much easier,measure the tube diameter before you order so you get a direct fit.
Old Jun 3, 2008 | 02:18 PM
fbaut15's Avatar
S500
Thanks, im currently waiting on answer from evosport.com because i couldnt fin any specs on the ones they sell. Ill waut for the answer and keep you posted.
Old Jun 3, 2008 | 09:43 PM
02S430's Avatar
W220 M113K
you can get it free from the dealer if ur under 80,000 miles or 8 years i had mine done at 68,000 check with ur dealer first
Old Jun 6, 2008 | 05:56 PM
Air-Force-1's Avatar
S 320 - 2001
Do you mean if the cat fails before 8 years or 80k miles, then MB will replace the cat for free??
thanks
Old Jun 6, 2008 | 06:05 PM
jfendis430's Avatar
S430 Sold :(
thanks
That is correct I had 59K miles on mine and both cats were replaced the are under warranty 8 years or 80k miles whatever comes first. 7K total I didnt pay a dime.
Old Jun 6, 2008 | 06:22 PM
S 320 - 2001
Exclamation
My S320 had a cat replaced last month, 74k on the clock, 6 years 8 months old. ($1,500/£750)
Maybe its just MB USA cars ?
I will check the UK forums .
thanks
Old Jun 6, 2008 | 07:28 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
I can confirm.. I had both mine replaced for free last years also... I had over 60K on the clock
Old Jun 6, 2008 | 09:46 PM
S500Miami's Avatar
S500
MB replaced one of mine at 78K. It was rattling too.
Old Jun 9, 2008 | 02:42 AM
Mustyzzle's Avatar
S320
thanks
Yes it seems to be only for USA.
Had the same prob with my S320 in belgium, got to the stealership and they just removed both cat (the one right after the engine :o )
They sayd "no, there is no prob with removing it"
Old Jan 25, 2014 | 06:38 PM
wrshot's Avatar
2001 S500
Catalytic converter issue recently?
Has anyone tackled replacing a catalytic converter on a 2001 S500 or similar recently? Wondering if any new suggestions on how to get rid of the rattling noises. Getting louder than my music now. Thank you in advance.
Old Jan 26, 2014 | 12:56 AM
tusabes's Avatar
Mercedes
There are muffler shops that can put in a universal aftermarket cat for less than $200 installed
