My new rotors are really rusty
Old Nov 20, 2008 | 04:31 PM
newton22's Avatar
BMW E39
When I ordered these Zimmermanns, they had an option to coat the rears but not the fronts. So I ordered coated rears and the only type of fronts they had (non-coated as you can see).
Well now after some 2 months, my rears still look silvery and great, but the fronts are looking like crap. What can I do? Rinse with WD-40 and then apply some kind of coating?
Old Nov 20, 2008 | 04:37 PM
Quadcammer's Avatar
96 and 08 911 turbos
just paint them silver
Old Nov 20, 2008 | 05:21 PM
newton22's Avatar
BMW E39
With what kind of paint? I'm not just gonna slap some Sherwin Williams paint onto my rotors.
Old Nov 20, 2008 | 05:32 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Thats exactly wht you do. I had the same issue..
sand the rust a little apply primer, then pain whatever color you want. I had a can of ceramic Red open at the time as I was doing my calipers so mine got red.FWIW black of gray/silver is better.
mine looked the same as your after a few weeks I couldn't stand it anymore. but its much cheaper to paint them yourself than to order precoated. I did my rears also.
Old Nov 20, 2008 | 08:26 PM
THR2008's Avatar
2000 S500
i dont think painted rotors are safe...if so enlighten me!
Old Nov 20, 2008 | 10:31 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
I'm with THR2008. Something about painting rotors just doesn't sound right. Also the thought of spraying WD-40 scares the hell out of me. I can see the pads having nothing to grip on after being coated with WD-40. Scary.
Old Nov 21, 2008 | 09:49 AM
Quadcammer's Avatar
folks, for the love of god.
You don't paint the friction surface, you just paint the hub. Not to mention, the brakes will burn off any paint left on the actual friction surface anyway.
So heres what you do.
Wrap newspaper around the friction surface and secure it with tape. Put some newspaper on the fender, and secure it.
Now, clean up the surface rust with some sandpaper.
Buy some primer (the rustoleum brand actually is pretty good), and then silver engine enamel (duplicolor works and will withstand the heat).
Prime the hub
Paint the hub
Allow to dry
Clear coat if you want.
do the other side.
Old Nov 21, 2008 | 04:13 PM
benz_addict's Avatar
V12TT
Prime the hub
Paint the hub
Allow to dry
do the other side.
LOL I was going to say the same thing but didn't bother they would be too paranoid when doing so.
This is how I did it, Just pop off wheel and using caliper paint (silver) I painted my calipers on the spot and the rotor hub. Obviously paint got on the rotor but after it dries up (30 min) take your car around the block and do some 'hard' braking. Everything will clear up.
Old Nov 21, 2008 | 04:51 PM
THR2008's Avatar
2000 S500
whew I thought you guys were crazy wd-40 on rotors and painting the rotors. I understand where you're talking about now. Thanks for enlightening me.
Old Nov 21, 2008 | 05:31 PM
HLG600's Avatar
2009 SL63 AMG
Prime the hub
Paint the hub
Allow to dry
do the other side.
Old Nov 21, 2008 | 05:33 PM
HLG600's Avatar
2009 SL63 AMG
Love the sig Newton. Those wheels are gorgeous and compliment the lines of the W220 well.
Old Nov 21, 2008 | 08:28 PM
my06clk's Avatar
This is how I did it, .............
LOL Same here. I decided not to bother with that one at all...
Old Nov 22, 2008 | 09:39 AM
Busa196's Avatar
2018 S63, lowered
I've never even used primer...and never coverd up the surface area on the rotor itself. I simply shot the hats on the rotor with silver high temp engine paint and was done. The over spray on the rotor (which is minimal if your careful) is off by the time you brake at the end of your street for the stop sign. Very simple to do- and a MUST IMO.
Old Nov 22, 2008 | 11:21 AM
Television's Avatar
CL500 216
do not know what paints you have over there but we have one called Hammerite, and you can paint it on rust,, the other way is to lightly sand the rotor clean and use an exhaust high temp paint.. Do not go near it with WD40
The one in the pic is high temp paint been on 2 years now, when you spray it you can wipe it off the rotor face with petrol / thinners
