Popping noise when turning lock-to-lock at standstill?
Old Mar 27, 2009 | 07:59 PM
dkinder's Avatar
Kleemann S55 AMG
I have noticed over the past few months that the S makes a pretty loud "pop" when say, turning the wheel nearly all the way left or right while the car is sitting still. I doesn't do it every time, but certainly enough to be annoying because it's loud enough for people to hear around the car. I checked out underneath and nothing looks obvious. Anyone ever run into this issue?
Old Mar 28, 2009 | 01:07 AM
Oxygen's Avatar
W220 S65 AMG
Same here.. No idea whats causing it.
Old Mar 30, 2009 | 06:15 PM
Oxygen's Avatar
W220 S65 AMG
Anyone? Bueller?
Old Mar 30, 2009 | 08:07 PM
02S430's Avatar
W220 M113K
hear it too after lowering the car
Old Mar 31, 2009 | 02:51 AM
SaibW220's Avatar
Have the same problem.. Someone told me its the
RACK AND PINION
But im not how sure because hes not a MB guy....
I only hear it when i steer the wheel all the way to the left ( i can see the power steering hose jumping) and when i jack up the car... and steer left all the way it doesnt have the sound... only on ground
im still lost
Old Mar 31, 2009 | 01:38 PM
Benz5656's Avatar
SL500
Lower control arm. My car did it when I turned the wheel to the right, and had to replace the left lower control arm. Its normally opposite from the way your turn. You didn't hear it on the lift because there was no stress from the weight of the car.
(Not sure why your hose is jumping, might be something else)
Old Apr 1, 2009 | 01:40 AM
SaibW220's Avatar
I change both side lower ball joint and lower control arm..
the sound still there..
Went to a MB Tech.. state its my driver side strut... im not sure if i should believe him because that sound doesnt make sense...???
Old Sep 8, 2009 | 04:22 PM
kadafone's Avatar
S430
I just went to the dealer and as I pulled up a mechanic was walking by, heard the clunk and squealing noise. He told me right away that it was the balljoint and strut arm(lower arm). I just ordered the parts on ebay for $250 both sides vs MB's $600.
Old Sep 9, 2009 | 05:22 AM
manano's Avatar
S350 2005
thanks Kadafone ... please keep us updated ... i'm having a similar sound, but it's not loud and pronounced as some of the other posters ... but irritating nonetheless ...
Manano
Old Sep 12, 2009 | 11:19 PM
choppy001's Avatar
w220
if the car is lowerd its the lower control arm went through 2 sets in the last 8 months did not even have them on for 2 weeks and the bushing towarrds the engine brakes
Old Sep 14, 2009 | 08:16 PM
kadafone's Avatar
S430
Well I finished the work today and WOW what a difference in braking, steering, and smoothness on highways. One problem is that a aftermarket ball joint is nearly if not impossible to put in a OEM arm. So I had to go to the dealer and buy a OEM ball joint. If your going to do the work yourself I would buy all parts from ebay dealer(Deutsche Parts) except for ball joints.
Old Sep 15, 2009 | 12:56 AM
Oxygen's Avatar
W220 S65 AMG
You can say that again! Change mine out too and what a difference.
