PLEASE!!! Help Suspension prob
Old Sep 27, 2009 | 07:08 PM
2003MB600's Avatar
2003 S600
Ok guys, I have looked high and low and have found some great info on this site, so thank you all for this forum.
My problems began over 4 months ago and I have danced around fixing it for some time now. 2003 S600 and when the car stays parked for a few days my passenger side basically bottoms out (front and rear). I can adjust it once in the car and have had the dealer change fluid because they said it was dirty (bs).
What caues this (relay, compressor, or a leak?) I plan on fixing it myself but need guidance as to what direction to head.
Thank you so much!!
Old Sep 27, 2009 | 07:23 PM
Quadcammer's Avatar
96 and 08 911 turbos
you have ABC, which doesn't have a compressor.
You may have a hydraulic leak or some valve block issues.
Old Sep 27, 2009 | 08:47 PM
2003MB600's Avatar
2003 S600
Thank you for the quick response. Any links that may help me diagnose the issue.
Soapy water and time I guess!
Is there a front and rear valve block or left and right side valve block?
Old Sep 27, 2009 | 08:55 PM
Quadcammer's Avatar
I believe there is still some confusion. The soap and water test works for the airmatic struts, as leaking air would cause bubbling.
It will not work on your ABC suspension, which is hydraulic oil under extremely high pressure (200 bar or 3000psi).
I think your best bet is to send a private message to member "oxygen" as he seems to have the most experience with ABC.
As for the valve block, I'm not 100% sure, so I won't speculate.
Old Sep 28, 2009 | 09:31 PM
2003MB600's Avatar
2003 S600
Does anyone have a break down of where the valve blocks and how the hydralic lines are run underneath the S600?
Thanks for your help!
Old Sep 28, 2009 | 10:01 PM
Quadcammer's Avatar
yeah, I'll post up the screens from epc tomorrow.
Old Sep 28, 2009 | 10:43 PM
2003MB600's Avatar
2003 S600
OliverK, thanks for the help!!!!
Old Sep 29, 2009 | 06:21 AM
2003 S600's Avatar
2003 s600
both are on drivers side front and rear, right in front of both wheels, remove underside cover. they leak internally, also the large spheres attached to valve blocks leak internally and cause a bumpy ride and may slam the vehicle.
I would start by changing abc fluid filter and flushing fluid if dirty, may help.
Old Sep 29, 2009 | 10:56 AM
S500 Man's Avatar
White S63 AMG W/Designo Interior
i would find an good indy shop man thats serious bussiness
Old Oct 19, 2009 | 11:43 PM
Revice's Avatar
2023 EQs 450+ & 2002 S430
AIRMATIC STOP CAR TOO LOW! HELP
Please help me! Today, for the first time ever...I got a RED message on my dashboard that said "Airmatic, STOP, car too low! WTF What does this mean? Eventually, it went off...I'm sure it will come back. HELP? What does this mean?
Old Oct 20, 2009 | 08:56 AM
Quadcammer's Avatar
Let me see.
IT MEANS YOUR CAR WAS TOO LOW.
You have a leak in your airmatic system.
find the leak
repair it
Old Oct 22, 2009 | 07:06 AM
DRTYLNDY's Avatar
Ok lets get this first part taken care of you do NOT have Airmatic you have ABC. My car did this but only the right rear dropped over time. It actually stopped doing it after 6 months or so. From what I have figured out you have a dirty valve block seat internally. Either you can deal with it or spend some serious cash to have it replaced. My car would say the same message but as soon as it started to move forward the car would raise it self. The dealer trying the fluid filtering sounds about right from what I have learned so far. I am also having a problem with my ABC right now. I am not sure if it is a pressure sensor/pulsation damper issue or if my ABC tandem pump just sucks. Hope this helps. If I think of anything else I will let you know.
Johan
Old Oct 22, 2009 | 07:42 PM
2003MB600's Avatar
2003 S600
Thanks man! Still trying to narrow down what it may be. 1600.00 for two valve blocks plus labor and fluid is gonna be a chunk.
Had a dealer flush the system but the problem still remains. I also understand that the system is under high amounts of psi so that part scares me a bit. I would love to fix it myself but who knows what else I may come across or need a special tool.
Old Oct 23, 2009 | 08:06 AM
DRTYLNDY's Avatar
You certainly do need a "special tool" to do work on your ABC suspension. You would need a computer with the Mercedes DAS software. Not so much to do the work but to flush/bleed the Pentocin fluid in the ABC.
