MY NEW COMAND NTG 2.5 project in 2000 W220 car.
Old Oct 17, 2009 | 09:03 AM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
This is my next big project..After installnig the Comand NTG 2.5 with bluetooth and built in hardrive and DVD changer in my wifes pre- facelift W203 I JUST MUST HAVE this comand in my S55...
As you can see here:
This upgrade works for models 1999-2003.
The comand it self almost fits directly...It is just the upper corners that is a bit wider. I am going to laser cut those corners so the comand fits perfectly...
Here you can see with a Audio 20 unit with same shape how "good" it fits unchanged...Just those upper corners..
To be continued....
Old Oct 17, 2009 | 01:37 PM
PlatinumEdition's Avatar
2022 S500
nice!
Old Oct 17, 2009 | 04:59 PM
Frank_S500's Avatar
SL63 (R230), CL500 (C215), SL55 (R129), CE300-24 Cabrio (A124)
Originally Posted by Chris The Swede
Hi Chris,
From the Nav picture it seem you are located at the MB HQ site. Are you MB Staff ?
Which Command unit are you using ? Are the D2B fibers reusable ?
I thought about a A230 command and modifying the upper panel instead (C215 MY 04 in this case)
Cheers, Frank.
Old Oct 18, 2009 | 04:30 AM
No Im in Sweden..I just used a navi pic from the net...
The unit is from the new CLC..Do you have dimensions of the R230 unit how it fits and what must be cut?
I am tesing my CLC unit in a short time to see if it all works..Dont know if the speed signal will work on it since the new unit takes it over can bus and I am not sure if W220 do that or cable wise.
Oh..And I think you have a AGW in your facelifted C215 and dont think a NTG 2.5 works in it..
Old Oct 19, 2009 | 02:18 AM
Frank_S500's Avatar
Hi Chris.
Since i have not had a Comand NTG2.5 available for testing i have only lots of assumptions.
The new comand has integrated some functions like AGW, BT phone & VCO. If its compatible with the interieur CAN bus as well as with the remaining soundsystem & CD Changer, i have no idea.
(At least my fiber optics would be feasible)
Cheers, Frank
Old Feb 28, 2010 | 06:11 AM
AdamGdefender's Avatar
W220 S500
Hi Chris,
Did you get any further with fitting a NTG 2.5 unit in a W220?
Cheers
Adam
Old Feb 28, 2010 | 06:33 AM
No I sold the car before I did.
Old Feb 28, 2010 | 06:42 AM
W220 S500
Thanks for the quick reply. Do you think the CLC NTG 2.5 will fit nicely with the corners trimmed?
Cheers
Adam
Old Feb 28, 2010 | 07:02 AM
Yes I do. But it wont work with a car that has the Bose system.
Old Feb 28, 2010 | 07:38 AM
W220 S500
It is tempting. I do not have bose sound. The question really is whether it is worth the cost. My present NTG 1 system is pretty good.
Thanks for the help,
Adam
Old Feb 28, 2010 | 08:11 AM
NTG1?? This only works on 99-03 cars..I think. Dont think newer W220 have the agw built in and so on.
Old Feb 28, 2010 | 08:33 AM
W220 S500
You are correct on the sytem in my car there is a seperate audio gateway (in the boot). I would have to dump this and run the speaker wires (amongst other things) to the head unit. If it wasn't for the cost of the parts it would be a good project.
Cheers
Adam
