Requirements for those interested in the 2003 Headlight group buy
Yes, the group buy is still on. You MUST have the following requirements if you want to order the 2003 Bi Xenon headlights
You have an S500
OR
You have an S430 with Xenons as a factory option
It is incredibly expensive to retrofit a vehicle for xenons (let alone bi-xenons) onto a vehicle that does not have xenons as a factory option.
If you do not have xenons as a factory option, the 2003 headlights WILL NOT WORK and I recommend getting the non-xenon 2003 headlights which doesn't require the use of a plug adapter and is a direct plug and play. Price is about $500 per side or $1009 per set (list price). I don't know what the group buy is but if anyone is interested, please PM. This latter option is mostly for S430 owners without the xenon factory option.
If you meet the above requirements, here is the pricing breakdown:
Description Group Buy (RETAIL)
2003 Headlights Right Side $1199 ($1320)
2003 Headlights Left Side $1199 ($1320)
Adapter relay Connector (2 per set) $299 ($399)
Total $2697 (group buy) $3239 (retail cost) ***
***Does not include the cost of installation which is about $200-300 dollars
Yes, a MB dealer OR a reputable body shop can install these lights. It's a plug and play connector and the dimensions for the 03 lamps remain the same. Most dealers are okay if it's a direct plug in which the connector provides. Also, there is no 'switching on' of the xenon controls in the car's copmputer since you need to have xenons already as a factory option to make this work anyways. You can source the services of a body shop for this installation because they won't have to mess with the car's computer. The front bumper must be removed in order to pull out the headlights.
Phil
Will the new light assembly "know" when to use the xenon high beam as opposed to the halogens?
Yes, the 03 High beam xenons will be compatible. How will the light assembly know? Well, that is the reason for having the adapter. There is an extra connector pin on the 03 lights that controls the shutter for the low and high beam XENONs and which is absent on the connector from the car side. The adapter bridges this connection and also resolves some of the voltage differences in powering the shutter motor. So when you pull the high beam lever for the 'old' xenon lights, it will activate the halogen high beam bulb. With the adapter in place when you pull the lever, it will signal the shutter motor on the low beam xenon to move to the high beam reflector position allowing for high beam xenons.
I haven't had a chance to do it on my car but the 5 that signed up have gotten theres with one guy being local and I got a chance to see it installed and the whole mod is very transparent with no glitches. I am waiting for my set to come in. It's about a week backorder on it. I will post pics once I get them and install them. Believe me, I am anxious to get them and take pics
Thanks for the explanation.
But, aren't there 2 different high beams? The regular halogens for the "flash" feature, which is activated when you pull the turn signal stalk towards you. While the bi xenon high beam is activated when you push the stalk forward.
Does it distinguish these two? Or, just use the xenon high beams all the time?
Thanks.
However, Hans, my mechanic (who is new to me, but highly recommended by local owners as a knowledgeable independent) told me that the change out doesn't work. When pressed he defines doesn't work as causing nothing but headaches.
Any comments from someone who has had this conversion done?
I am going to check with a high end body shop to see if they will do the work and know anything about it.
You might notice that the group buy happened over 3 years ago! I, too was interested, but have just placed an order for the Depo ones from Taiwan.
so how much did the ones u bought from depo cost?
Oh well, if they don’t work, one of you guys in the US might get a good deal on a set of front lights. LOL.
You have an S500
OR
Ansonnn:
How do I reach you to order these items?
M Rippley
888-636-0711
mrippley@outreachcom.com
How do I reach you to buy the headlight sets?
M Rippley
888-636-0711
I did not realize this was that old. Can you steer me to someone that wuold know what he is talking about. I want to put the '03 Xenon projector lihgts into my 2000 S 430 (with factory Xenons) and the fitting in the back of the headlighrts are different. Soemone obviously makes an adpator becasue he references it in his post. DO you know where I can go to get one?
M Rippley
M Rippley
888-636-0711
http://www.procarparts.com/store-det...=onlinestoreDB
http://cgi.ebay.com/ebaymotors/99-02...QQcmdZViewItem
