Nav Disk #9
Old May 3, 2011 | 08:14 AM
LAL's Avatar
LAL
2000 S500
Nav Disk #9
I have a S500 2000 and i need a #9 Navagation disk CD not the DVD anyone have one or know where i can get one or a copy of one ?? CD not DVD i have DVD and it just reads error. I tried dealers and even Navtech and none around.
Old May 4, 2011 | 12:43 AM
mobilusa's Avatar
2001 s 430 84Kmiles black on black
I think i have the one you are looking for. If you are from Florida, then it should be about right. My 2001 S430 was in FtLauderdale since day 1 until i moved to NY area about 3 yrs ago. So i still have this Nav CD and can't really get use of it, since it only good for Florida, Virginia, Georgia, NC,SC area
Do you have any other CD's to trade or if you want mine, give me an offer
cheers
Old May 4, 2011 | 09:34 AM
LAL's Avatar
LAL
2000 S500
Check your email. Thanks
Old May 4, 2011 | 09:51 AM
LAL's Avatar
LAL
2000 S500
Trying to find the correct disk is not easy. Early 2000 used a CD and then they switched to a DVD system. I have a #7 that works but it New England and i am in South Florida.The one that works has to be a CD. Bosch rel 7/00 Q6 46 0059. I think the Bosch rel date is important.I have a #9 Bosch rel 7/01 Q6 46 0093 that don't work so it must be a DVD.
Old May 4, 2011 | 11:15 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
See http://www.benzworld.org/forums/w220...upgrade-2.html and https://mbworld.org/forums/s-class-w...257-d-nav.html to find out which CD version you need. "C" nav and "D" nav are not compatible, and both were used in MY '00.
Old May 4, 2011 | 11:40 AM
LAL's Avatar
LAL
2000 S500
Thanks for the reply. I had already did the test and also i called Dealer and gave vin # and he confirmed i have C model and i need CD's not DVD's. Dealer gave me this # BQ 6 46 0191 as the latest.
Old May 4, 2011 | 01:50 PM
mobilusa's Avatar
I didnt get an email. send me Personal Message here on forum. I believe i have the C nav CD
Old May 4, 2011 | 01:51 PM
mobilusa's Avatar
By the way, does anybody can make a copy of CD for NY, PA, NJ area? for 2001 S430
Old May 4, 2011 | 05:02 PM
Skylaw's Avatar
Please don't be confused by the designation "C" nav and "D" nav. Both types use CDs, but they use entirely different file formats. "D" nav does not imply that the system used DVDs. That did not happen until MY 2004. BQ 6 46 0191 is also the latest set for which I have information for "C" nav discs. Note that they were last updated in 2004.
If you can find a set, you might want to snap them up; there aren't many available.
Old May 4, 2011 | 07:09 PM
LAL's Avatar
LAL
2000 S500
Skylaw Thanks for your replys. Yes there is confusion about CD and DVD units. I was told the same think you posted, about it. I definately have a C Model nav system verified by the Dealer. The dealer also said latest disk for C model is what you posted Q6 46 0191.
Old May 5, 2011 | 03:01 AM
kevint's Avatar
S430 4Matic
I have an S430 4matic 2003. It uses a CD for nav. I called Mercedes dealer couple days ago and was told that Mercedes releases Navigation CDs 2-3 times per year. They have not released any for year 2011. And I was told it 's a good idea to wait. The person I talked to mentioned the latest released was 2010. Is he right or he new and doesn't know what he talks about. My CD was released in 2002, too old map. I need a new map for my job. I can't find many new neighborhood with the 2002 ver.. Reading through your posts, seems like Mercedes only release Nav cd till 2004. Anyone knows about this experience please post. I live in WA state and need CD#2, if anyone has the latest ver and wants to sell, please contact me, i don't mind using a copy one as long as it works. I get tired of my useless navigation in the car.
Old May 5, 2011 | 07:37 AM
LAL's Avatar
LAL
2000 S500
Kevint...If you have a "C" model nav the last update was 2004 Q 6 46 0191 You should give your vin # to dealer to see what model you have in your car "C" or "D" model. You are limited to what i posted above if it is a C model. You can also see the hyper links posted above by Skylaw to see what model you have in your car.
Old May 5, 2011 | 09:36 AM
Skylaw's Avatar
You're not reading closely enough. Some of what follows should have been clear from the links and discussion above - but here's the brief rundown for U.S. and Canadian cars.
1) "C" nav was used in early production MY 2000 W220s, and the last CD set for "C" nav, Q 6 46 0191, was updated in 2004. "C" nav discs are NO LONGER UPDATED.
2) "D" nav discs are used in later production MY 2000 W220s, and were also used through the 2003 model year (yes, including the wide screen COMAND MOPF). "D" nav discs are still being updated - at least, they were through 2010. You can no longer order them through NavTeq, but you can get them through the dealer. You should be able to get current "D" nav CDs for your '03. Check with your dealer for the date of the last release he has, and see if you can get the time frame for the next release (probably February 2011, but there is no guarantee). The last "D" nav CD set I am aware of was Release 2/10 and part number was Q 6 46 02473. There may have been a newer release; I don't really track the CD set releases. A newer release would have a higher part number. If you come across newer information, I am sure members would appreciate knowing.
NOTE: The changeover from "C" to "D" nav occurred in November 1999, but I do not know the exact date. The placard in the driver's door frame provides your date of manufacture. It is also possible, if you have an MY 2000 W220, that its COMAND unit has been replaced; therefore, you should always use the simple check at post #2, https://mbworld.org/forums/s-class-w...257-d-nav.html to see which system is actually installed in your car.
3) MY 2004 and later W220s use DVDs, which are updated (approximately) annually. These are still available through NavTeq as well as the dealer. However, if you skip several years of nav updates with DVD systems, you may need the dealer to install an interim nav system update. The explanation as to why is lengthy, so I won't repeat it here. See post 12 at http://www.benzworld.org/forums/audi...de-mode-2.html
4) There are different disc sets covering several different groupings of Mercedes models. Check the NavTeq compatibility list for your model year on the NavTeq site (or even the box for the disc you now have) to see which models share the same disc set. Each type of disc is updated only once a year (approximately), but the updates are released at different times of the year. Therefore, a dealer receives updates "several times a year" but the disc for your car is only updated annually. The update for the W220 usually appears somewhere between November and February. For example, a November, 2010 release would be the 2011 update (as would a February 2011 release).
5) You can check the NavTeq site to see when a new disc has been released (by version number; at the time of this post, the current W220 DVD is v.10) but NavTeq does not provide the date of release on the site. The dealership can correlate the NavTeq disc designation with its release date. There is absolutely no difference between a DVD obtained from NavTeq and one obtained from a dealer. However, if you have skipped updates and require an interim nav system update, the dealer will ordinarily install it free if you purchase from him; he may charge you if you bought from NavTeq.
Old May 5, 2011 | 10:37 AM
LAL's Avatar
LAL
2000 S500
Some info to see what system you have by vin # and what part # you need for your system. C model or D model.
Mercedes S CL C CLK E G NAV CDs North America (Blaupunkt COMAND 2.0/2.5 model year 2000-2005)
00 S-Class COMAND 2.5 until 8/99, VIN to A078551: 10 CD set, "C", version 2004-1 (MB part# Q6-46-0191)
00 S-Class COMAND 2.5 from 9/99, VIN A078551 can use the "D" or "DX" CDs listed below:
01-03 S/CL 01-04 C/CLK 00-02 E 02-05 G, 10 CD set, version 2005-2, release 8/05 (MB part# Q6-46-0215)
01-03 S/CL 01-04 C/CLK 00-02 E 02-05 G, 10 CD set, version 2007-1, release 1/07 (MB part# Q6-46-0222)
Old May 5, 2011 | 11:00 AM
Skylaw's Avatar
Thanks, but not quite. The 01-03 S/CL 01-04 C/CLK 00-02 E 02-05 G, 10 CD set has been updated several times since then. A later part number and release date (release 2/10 - i.e., 2010-2, and part number Q 6 46 02473) are in the post above. There could have been even a more recent update.
Unfortunately, the site that was the source of that list has not been updated for years, and is not even available anymore (I used to refer to it frequently).
Old May 5, 2011 | 11:31 AM
LAL's Avatar
LAL
2000 S500
Skylaw i am sure you are correct with that update. I was posting that info i guess more for what model nav is in the car. I know this info is correct.
This is what i am looking for and i just C/P all that info off a web site i found in searching for what i am looking for. Thanks for the update on the other disk part #'s.
Old May 5, 2011 | 12:26 PM
kevint's Avatar
S430 4Matic
Thanks Skylaw for a clear explaination post. I have checked my system and learn that mine is D nav, yeah. I can update.
Here is how to check for someone who comes to the forum and can't find it somewhere else: Press the Detour ( “ DETR” ) button on the COMAND upper-right keypad. The C navi has only the “Traffic Jam” option. The D navi has both the “Traffic Jam” as well as the “Detour in Route” option.
Mine shows both detour and traffic jam. The traffic jam option can't be selected. I guess no traffic jam or traffic jam subcription has expired. Car is 2003.
According to posts above, 2010 release is for 2011 use. I may go ahead and order the 2010 version, the latest available right now. I will need cd#2 for my WA state driving. Anyone need to other CDs, let me know.
Old May 6, 2011 | 12:14 PM
LAL's Avatar
LAL
2000 S500
mobilusa you have a pm
Old May 7, 2011 | 07:24 PM
mobilusa's Avatar
I responded to your PM. I do have 2001 S430 which came with
Nav CD BOSCH Rel 7/00 Q 6 46 0061
Old May 7, 2011 | 08:05 PM
Nola's Avatar
Super Moderator Alumni
Audi A5 Sportback + Cannondale Prophet
Please, no discussions of trading copies of nav cd's. Nav CD's are copyrighted material, so discussing this is against our TOU.
Carry on.
Old May 7, 2011 | 08:36 PM
LAL's Avatar
LAL
2000 S500
Thanks Nola...mobilusa u have a pm.
Old May 15, 2011 | 09:46 AM
LAL's Avatar
LAL
2000 S500
FYI........Mission accomplished.
Old May 16, 2011 | 02:47 PM
mobilusa's Avatar
Yeap. We have exchanged CD's and now everyone is happy! )
It's not like i have use GPS a lot, but if you go somewhere else for the first time, GPS Navi will come handy!
Thanx LAL
Old May 27, 2011 | 09:49 PM
Twisted1's Avatar
cl 55
which ones do you want to sell
Old Sep 2, 2011 | 04:30 AM
kevint's Avatar
S430 4Matic
I have just bought a set of Navigation CD for COMAND from Philsmart Mecerdes. I only needs Disk 2. Anyone wants any single Disk for your area, please contact me. $45/disk include shipping with delivery tracking #. These are newest release of this year 4/2011. These CD ROMs are compatible with the following vehicles (D Nav Only):
2000 S/CL, CLK, E Class
2001 S/CL, C/CLK, E Class
2002 S/CL, C/CLK, E, G Class
2003 S/CL, C/CLK, SL, G Class
2004 G, C/CLK, SL class
2005 G class
*Early 2000 model may require C Nav, please check your vehicle.
Disk 1: California/Nevada/Hawaii (Oahu)
Disk 3: Iowa/Kansas/Minnesots/Missouri/Nebraska/N and S Dakota/Illinois/Michigan/Wisconsin.
Disk 4: Arkansas, Louisiana, Mississippi, Oklahoma, and partial of Tennessee, Texas
Disk 5: Illinois/Indiana/Michigan/Ohio/Wisconsin/New York/Ohio/Pennsylvania/Tennessee.
Disk 6: Kentucky/W Virgina/Indiana/Maryland.
Disk 7: Connecticut/Maine/Massachusetts/New Hampshire/Rhode Isle/Vermont/New Jersey/New York.
Disk 8: Delaware/Virgina/Washington D.C./Maryland/New Jersey/N. Carolina/Pennsylvania.
Disk 9: Alabama/Florida/Georgia/South Carolina/North Carolina.
Disk 10: Vancouver/British Columbia/Alberta/Manitoba/Saskatchewan and Yukon Territory/Toronto/Ontario/Montreal/Quebec/New Brunswick/Newfoundland/Nova Scotia/Ontario/Prince Edward Isle/Quebec.
Send me a message with your contact info, I can give you my email or phone #. If you can pay by Paypal which is great. I think this is the only method I can accept.
